Picture Alignment Vertical will not work ??
MJ68
MJ68 posted this 14 July 2016
i want to align a picture Vertiacl in the middle on Sidebar right.
It will not work?
Michael
Hi, i want to align a picture Vertiacl in the middle on Sidebar right. It will not work? !AlignVertMid.PNG! Thanks Michael
MJ68
The pictures wanto to be aling Vertical in sidebar.
https://abnehmen-ganz-einfach.info/blog/impressum/
https://abnehmen-ganz-einfach.info/blog/kontakt/
https://abnehmen-ganz-einfach.info/blog/haftungsausschluss/
The pictures wanto to be aling Vertical in sidebar. https://abnehmen-ganz-einfach.info/blog/impressum/ https://abnehmen-ganz-einfach.info/blog/kontakt/ https://abnehmen-ganz-einfach.info/blog/haftungsausschluss/
Support Team posted this 15 July 2016
The Vertical align will not work in this case.
And you need to center the whole widget area. Please try the following solution:
  1. open Widget area options:
  2. apply the following settings:
NOTE: Please do not adjust the position of the Widget area manually in the preview. This will change the "top" offset and break the centering.
Hi, The Vertical align will not work in this case. And you need to center the whole widget area. Please try the following solution: 1. open Widget area options: !widget-area-options.png! 2. apply the following settings: !vcenter-widget-area.png! NOTE: Please do not adjust the position of the Widget area manually in the preview. This will change the "top" offset and break the centering. Please let us know the result. Thank you, Olivia
MJ68
MJ68 posted this 15 July 2016
It Works.
I would never have guessed.
Michael
It Works. I would never have guessed. Thanks Michael
