Hi Support,
Strange issue. I have a theme created in themler and it was working fine (bar the swatches issue...different bug). I made a change to the theme , just updated aimage http link and re-uploaded the changed theme and it now seems that the short description in the product details does not show the normal bullet points but shows instead text "Learn More" which is clickable but goes nowhere.
As a test I have a xampp local magentio install with same theme (prior to the http change) /same magento version etc and the short description has the bullet points as expected. Basically this was an identical setup as on the live site (full copy) , so I updated to the newer template with the http change on the image and now the local version also has the issue.
I also if revert back to the older theme the issue is gone......
Any ideas?, its affecting al products.
Hi Support, Strange issue. I have a theme created in themler and it was working fine (bar the swatches issue...different bug). I made a change to the theme , just updated aimage http link and re-uploaded the changed theme and it now seems that the short description in the product details does not show the normal bullet points but shows instead text "Learn More" which is clickable but goes nowhere. As a test I have a xampp local magentio install with same theme (prior to the http change) /same magento version etc and the short description has the bullet points as expected. Basically this was an identical setup as on the live site (full copy) , so I updated to the newer template with the http change on the image and now the local version also has the issue. I also if revert back to the older theme the issue is gone...... Any ideas?, its affecting al products.
