captcha Code
MJ68
MJ68 posted this 15 July 2016
i want to ask where i must put the captcha code?
This is a google div blog.
and there will be a script
Michael
Hi, i want to ask where i must put the captcha code? This is a google div blog. and there will be a script Thanks Michael
49 Comments
Support Team posted this 18 July 2016
Hello Michael,
I suppose that you have got ready solution and would like to incorporate it into Themler, right?
if so, you may need HTML Control. Put there the HTML code which creates DIV. And relevant JS code.
Let us know if you have additional questions
Hello Michael, I suppose that you have got ready solution and would like to incorporate it into Themler, right? if so, you may need HTML Control. Put there the HTML code which creates DIV. And relevant JS code. Let us know if you have additional questions regards, Aileen
MJ68
MJ68 posted this 18 July 2016
I had installed the Contact Form 7 Plugin and make the Forms secret with Google Captcha.
For that it will be work fine.
Now i want to make it sectrat when someone will write an comment.
I had an div Blog and JS script from Google.
I dont know where i must place these code in themler?
Must be insert an HTML Box?
And where?
Michael
I had installed the Contact Form 7 Plugin and make the Forms secret with Google Captcha. For that it will be work fine. Now i want to make it sectrat when someone will write an comment. I had an div Blog and JS script from Google. I dont know where i must place these code in themler? !comment.PNG! Must be insert an HTML Box? And where? Thanks Michael
Support Team posted this 19 July 2016
Hello Michael,
as far as I know the Contact Form 7 creates forms which are added to pages, posts, widgets as shortcodes.
So add the form shortcode to page or post or widget on the WP admin back end. Or add the shortcode directly in Themler using Shortcode control.
Hello Michael, as far as I know the Contact Form 7 creates forms which are added to pages, posts, widgets as shortcodes. So add the form shortcode to page or post or widget on the WP admin back end. Or add the shortcode directly in Themler using Shortcode control. regards, Aileen
MJ68
MJ68 posted this 19 July 2016
I had to try a shortcode in this section, but it will not place there.
The only Place for Captcha is under the comment input, noone else.
I had to try a shortcode in this section, but it will not place there. The only Place for Captcha is under the comment input, noone else.
Support Team posted this 20 July 2016
Hello Michael,
it looks like we have misunderstood each other a bit.
The Captcha is in fact part of the form. The form in your case is built with Contact Form 7 plugin. As far as I know such form may include Captcha and there's no need to add it separately.
Is that right? Please correct me if I'm wrong.
As for my recommendation regarding the shortcode, I meant the shortcode specific for the Contact Form 7 form, the shortcodes which outputs the form.
Hello Michael, it looks like we have misunderstood each other a bit. The Captcha is in fact part of the form. The form in your case is built with Contact Form 7 plugin. As far as I know such form may include Captcha and there's no need to add it separately. Is that right? Please correct me if I'm wrong. As for my recommendation regarding the shortcode, I meant the shortcode specific for the Contact Form 7 form, the shortcodes which outputs the form. regards, Aileen
MJ68
MJ68 posted this 20 July 2016
Hi Aileen,
yes i know it is correct.
i had implement the captcha in my contact Form.
I want to implement it too in the commend form.
I want to lose spam that write spamm comment.
the i need to impelemt the recaptch from google into area from comments.
I dont know where i must impelemt the captcha code for the comments?
Michael
Hi Aileen, yes i know it is correct. i had implement the captcha in my contact Form. I want to implement it too in the commend form. I want to lose spam that write spamm comment. the i need to impelemt the recaptch from google into area from comments. I dont know where i must impelemt the captcha code for the comments? Thanks Michael
Support Team posted this 21 July 2016
To implement the captcha in the comments form you will need to edit the exported theme and insert the code in the comments file. We do not support such custom modifications.
Maybe you could find some specific comments plug-in that will do that automatically.
Hi, To implement the captcha in the comments form you will need to edit the exported theme and insert the code in the comments file. We do not support such custom modifications. Maybe you could find some specific comments plug-in that will do that automatically. Sincerely, Hella
MJ68
MJ68 posted this 21 July 2016
Hi Hella,
thank you.
I had isntalled much different Plugins.
One of them will be work fine.
The other i had deinstalled.
P.S. Can you show about these Post?
This is very important for me today.
https://answers.themler.com/questions/89724/template-style-will-not-apply
Hi Hella, thank you. I had isntalled much different Plugins. One of them will be work fine. The other i had deinstalled. Thank you P.S. Can you show about these Post? This is very important for me today. https://answers.themler.com/questions/89724/template-style-will-not-apply Thank you
We'll respond to that case as soon as possible. This one I'm closing now.
Hi, We'll respond to that case as soon as possible. This one I'm closing now. Sincerely, Hella
kelseyradleyyy
kelseyradleyyy posted this 07 October 2023
I tried inserting a shortcode in this part, but it did not work.
Captcha is only used under the comment input; nowhere else. io games
I tried inserting a shortcode in this part, but it did not work. Captcha is only used under the comment input; nowhere else. [io games][1] [1]: https://iogamesio.org
timothyferrissy
timothyferrissy posted this 25 December 2023
Typically, when integrating a CAPTCHA (like Google's reCAPTCHA) into a website, you'll want to place the CAPTCHA code within the HTML immaculate grid form that you're trying to protect from spam or automated submissions.
Typically, when integrating a CAPTCHA (like Google's reCAPTCHA) into a website, you'll want to place the CAPTCHA code within the HTML [immaculate grid][1] form that you're trying to protect from spam or automated submissions. [1]: https://immaculategrid.io
foodlenyt88
foodlenyt88 posted this 28 December 2023
It is my opinion that it is helpful to spend some time playing games like these on sometimes since they assist to relieve stress; however, it is not a good idea to do so on a regular basis because it may cause you to disregard other commitments. trap the cat game
It is my opinion that it is helpful to spend some time playing games like these on sometimes since they assist to relieve stress; however, it is not a good idea to do so on a regular basis because it may cause you to disregard other commitments. [trap the cat game][1] [1]: https://trapthecat.net
iampriyankapluss
iampriyankapluss posted this 03 February 2024
We offer inside and outside Escorts Service Noida so with us you every sex need complete and you feel so happy with us and our model when start to treat you that time you feel like you are in heaven because our girls know all position of sex that a people have dream when he hire any Noida escort.
We offer inside and outside [Escorts Service Noida][1] so with us you every sex need complete and you feel so happy with us and our model when start to treat you that time you feel like you are in heaven because our girls know all position of sex that a people have dream when he hire any Noida escort. [1]: https://www.julieoberoi.com/noida-call-girls.html
swarnayadv
swarnayadv posted this 16 May 2024
Well, Delhi call girls can be damn sexy for you, and they can really push their limits too. If you haven’t been with a sexy woman lately, then you should hire from us right now. Our list of hotties are just the best, and they can provide you all the love you want. There are tons of other call girl agencies too, but none of them are like us. We are unique, and our services are damn great too. Moreover, we always hire those women who are super horny, and who excels in providing call girl services. The kind of eroticism you get from us will definitely blow your mind away.
Well, [Delhi call girls][1] can be damn sexy for you, and they can really push their limits too. If you haven’t been with a sexy woman lately, then you should hire from us right now. Our list of hotties are just the best, and they can provide you all the love you want. There are tons of other call girl agencies too, but none of them are like us. We are unique, and our services are damn great too. Moreover, we always hire those women who are super horny, and who excels in providing call girl services. The kind of eroticism you get from us will definitely blow your mind away. [1]: https://www.delhiqueen.in/delhi-call-girls.html
missrubygoa
missrubygoa posted this 11 June 2024
Surprised to learn that tantric massage can also be offered with nice extras, so you don't have to miss the end result. Each of our passionate Mohali Escort knows that it is an essential part of any action. It is priceless to have a classy, discreet, mature, intimate, and good option. After messaging or calling, you can easily see the results for yourself.
Surprised to learn that tantric massage can also be offered with nice extras, so you don't have to miss the end result. Each of our passionate [Mohali Escort][1] knows that it is an essential part of any action. It is priceless to have a classy, discreet, mature, intimate, and good option. After messaging or calling, you can easily see the results for yourself. [1]: https://www.missruby.in/mohali-call-girls.html
missrubygoa
irwansarwoto
irwansarwoto posted this 20 June 2024
Helpful answer by the team. Thank you for the quick and easy solution. Now, I can resume my project in peace. Slot88
Helpful answer by the team. Thank you for the quick and easy solution. Now, I can resume my project in peace. [Slot88][1] [1]: https://shirleyvalentineonstage.com/
swarnayadv
swarnayadv posted this 09 July 2024
Dating Call Girl and connect with females Call Girls Lucknow could be an incredible experience for you. There are numerous hot females prepared to assist you their own remarkable arrangements and experience with bettering than any time in recent memory.
Dating Call Girl and connect with females [Call Girls Lucknow][1] could be an incredible experience for you. There are numerous hot females prepared to assist you their own remarkable arrangements and experience with bettering than any time in recent memory. [1]: https://www.delhiqueen.in/lucknow-call-girls.html
topgirlsfun
topgirlsfun posted this 14 August 2024
In Karnal, are you trying to find a high-class call girl? Are you weary of looking for the ideal friend? If so, you ought to contact us as we are among the finest Call Girls in Karnal, providing excellent in-call and out-of-call services. Our Karnal call girls are quite competent and have a knack for winning over guys.
In Karnal, are you trying to find a high-class call girl? Are you weary of looking for the ideal friend? If so, you ought to contact us as we are among the finest [Call Girls in Karnal][1], providing excellent in-call and out-of-call services. Our Karnal call girls are quite competent and have a knack for winning over guys. [1]: https://aminah.in/call-girl-in-karnal.html
sanskaririyasharma
sanskaririyasharma posted this 24 September 2024
On our website, go to the gallery section and select the perfect partner that suits your personality. Our Gurgaon escort service are intelligent and beautiful and know how to fulfill all the wild fantasies of the clients.
On our website, go to the gallery section and select the perfect partner that suits your personality. Our [Gurgaon escort service][1] are intelligent and beautiful and know how to fulfill all the wild fantasies of the clients. [1]: https://www.gurgaonqueen.in
