Custom placements for Header Headline and Slogan on different devices
Pixagraphics Studio
Pixagraphics Studio posted this 18 July 2016
In Artisteer one can set "Switch to Custom responsive" and then drag the Headline and Slogan to a specific placement on tablet and mobile view.
How does one do this in Themler?
In Artisteer one can set "Switch to Custom responsive" and then drag the Headline and Slogan to a specific placement on tablet and mobile view. How does one do this in Themler?
Support Team posted this 18 July 2016
In Themler you should do it with the help of options like margins if the element Positioning is set to relative. In case you set it to be absolute in container, then you can switch to each responsive mode and drag the element or use the top, right, bottom and left option to position it.
Hi, In Themler you should do it with the help of options like margins if the element Positioning is set to relative. In case you set it to be absolute in container, then you can switch to each responsive mode and drag the element or use the top, right, bottom and left option to position it. Sincerely, Hella
