Using Themler with Vrtuemart and Joomla
How do I set up a multi column menu?
If you do not which to implement the prediction?
It will be very good, if I have to put the image of a featured product in horizontal multi column menu.
Att..
Amilcar
Using Themler with Vrtuemart and Joomla How do I set up a multi column menu? If you do not which to implement the prediction? It will be very good, if I have to put the image of a featured product in horizontal multi column menu. Att.. Amilcar
