I would like to add sections to my homepage, but the same time I would like to have a sidebar.
The section should be the same width as my content, but only on the homepage template.
When I try to add the section the sidebar is moved to below the section, it should align with the menuebar
The problem I have is when I add sections to the content I have all those section on my other pages. It
should only be on the homepage template.
See attachment
Thanks for your help
Henk
Hi, I would like to add sections to my homepage, but the same time I would like to have a sidebar. The section should be the same width as my content, but only on the homepage template. When I try to add the section the sidebar is moved to below the section, it should align with the menuebar The problem I have is when I add sections to the content I have all those section on my other pages. It should only be on the homepage template. See attachment Thanks for your help Henk
