Can you Help Me
bolgeselrehber
bolgeselrehber posted this 19 July 2016
l have a problem like this
INFO:Version files finded:
INFO: C:\PROGRA~3\Themler\1.0.319.25.ver
INFO:Check free disk space...
INFO:Check Services...
ERROR:MySQL service isn't started
INFO:Check Files...
INFO:Check HTTP Server...
INFO:Check url for C:\PROGRA~3\Themler\hd_data\themler_4052686469
INFO: Check is url available: http://localhost:12080/themler_4052686469/startup
INFO:Check INI Files...
INFO:No errors!
======== Content of file C:\Program Files (x86)\Themler\bin_logs\bat_exec.log ========
Program files detected C:\Program Files (x86)
Must be on program files\themler\bin
C s�r�c�s�ndeki birimin etiketi yok.
Birim Seri Numaras�: 08B6-9391
C:\Program Files (x86)\Themler\bin dizini
19.07.2016 12:56 <dir> .
19.07.2016 12:56 <dir> ..
19.07.2016 12:56 <dir> 7zip
19.07.2016 12:56 <dir> apache
19.07.2016 12:56 <dir> diagnostics
22.06.2016 15:18 1.402 install-apache.bat
22.06.2016 15:18 2.724 install-mysql.bat
19.07.2016 12:56 <dir> mysql
19.07.2016 12:56 <dir> php
22.06.2016 15:18 1.730 uninstall-apache.bat
22.06.2016 15:18 1.695 uninstall-mysql.bat
19.07.2016 12:56 <dir> _logs
</dir></dir></dir></dir></dir></dir></dir></dir> 4 Dosya 7.551 bayt
           8 Dizin      434.905.088 bayt bo�
creating logs just in case
C:\ProgramData\Themler alt dizini ya da dosyas� halen var.
C:\ProgramData\Themler\logs alt dizini ya da dosyas� halen var.
Cr
19.07.2016 13:00 <dir> _logs
           8 Dizin    1.060.290.560 bayt bo�
Cr
======== End of file C:\Program Files (x86)\Themler\bin_logs\bat_exec.log ========
ERROR:Unable to find file C:\ProgramData\Themler\logs\Themler_vbs.log
ERROR:Unable to find file C:\Users\Murat\AppData\Local\Themler\Themler_vbs.log
======== Content of file C:\ProgramData\Themler\logs\startup.php.log ========
Tue, 19 Jul 2016 10:00:57 +0000
run from browser =
suffix = _4052686469
themlerDataPath = C:/ProgramData/Themler
icPath = C:/ProgramData/Themler/hd_data/themler_4052686469
url = http://127.0.0.1:12080/themler_4052686469
versionFile not exists
UnZip successful, target directory exists
Replace common.php result is 3930
======== End of file C:\ProgramData\Themler\logs\startup.php.log ========
======== Content of file C:\ProgramData\Themler\logs\apache\error.log ========
AH00558: hthemlerd.exe: Could not reliably determine the server's fully qualified domain name, using fe80::703b:6e2c:c9a8:7145. Set the 'ServerName' directive globally to suppress this message
[Tue Jul 19 13:00:54.529296 2016] [mpm_winnt:notice] [pid 2568:tid 720] AH00455: Apache/2.4.16 (Win32) PHP/5.4.42 configured -- resuming normal operations
[Tue Jul 19 13:00:54.541015 2016] [mpm_winnt:notice] [pid 2568:tid 720] AH00456: Server built: Jul 13 2015 10:37:15
[Tue Jul 19 13:00:54.541015 2016] [core:notice] [pid 2568:tid 720] AH00094: Command line: 'C:\Program Files (x86)\Themler\bin\apache\bin\hthemlerd.exe -d C:/Program Files (x86)/Themler/bin/apache'
[Tue Jul 19 13:00:54.551757 2016] [mpm_winnt:notice] [pid 2568:tid 720] AH00418: Parent: Created child process 1688
[Tue Jul 19 13:00:55.203125 2016] [mpm_winnt:notice] [pid 1688:tid 668] AH00354: Child: Starting 64 worker threads.
======== End of file C:\ProgramData\Themler\logs\apache\error.log ========
======== Content of file C:\ProgramData\Themler\logs\apache\access.log ========
::1 - - [19/Jul/2016:13:07:15 +0300] "GET /themler_4052686469/startup HTTP/1.1" 301 258 35157 mis
::1 - - [19/Jul/2016:13:07:15 +0300] "GET /themler_4052686469/startup/ HTTP/1.1" 200 30311 1174805 mis
::1 - - [19/Jul/2016:13:07:28 +0300] "GET /themler_4052686469/startup HTTP/1.1" 301 258 0 mis
::1 - - [19/Jul/2016:13:07:28 +0300] "GET /themler_4052686469/startup/ HTTP/1.1" 200 30311 1355469 mis
::1 - - [19/Jul/2016:13:07:47 +0300] "GET /themler_4052686469/startup HTTP/1.1" 301 258 0 mis
::1 - - [19/Jul/2016:13:07:47 +0300] "GET /themler_4052686469/startup/ HTTP/1.1" 200 30311 1944336 mis
::1 - - [19/Jul/2016:13:08:20 +0300] "GET /themler_4052686469/startup HTTP/1.1" 301 258 0 mis
::1 - - [19/Jul/2016:13:08:20 +0300] "GET /themler_4052686469/startup/ HTTP/1.1" 200 30311 1364258 mis
::1 - - [19/Jul/2016:13:10:52 +0300] "GET /themler_4052686469/startup HTTP/1.1" 301 258 0 mis
::1 - - [19/Jul/2016:13:10:52 +0300] "GET /themler_4052686469/startup/ HTTP/1.1" 200 30311 1560547 mis
::1 - - [19/Jul/2016:14:41:40 +0300] "GET /themler_4052686469/startup HTTP/1.1" 301 258 169922 mis
::1 - - [19/Jul/2016:14:41:40 +0300] "GET /themler_4052686469/startup/ HTTP/1.1" 200 30311 1877930 mis
::1 - - [19/Jul/2016:14:43:10 +0300] "GET /themler_4052686469/startup HTTP/1.1" 301 258 977 mis
::1 - - [19/Jul/2016:14:43:10 +0300] "GET /themler_4052686469/startup/ HTTP/1.1" 200 30311 377930 mis
::1 - - [19/Jul/2016:14:43:20 +0300] "GET /themler_4052686469/startup HTTP/1.1" 301 258 977 mis
::1 - - [19/Jul/2016:14:43:20 +0300] "GET /themler_4052686469/startup/ HTTP/1.1" 200 30311 379883 mis
::1 - - [19/Jul/2016:18:23:31 +0300] "GET /themler_4052686469/startup HTTP/1.1" 301 258 774414 mis
======== End of file C:\ProgramData\Themler\logs\apache\access.log ========
======== Content of file C:\ProgramData\Themler\logs\mysql\error.log ========
InnoDB: 1048576 bytes should have been written, only 0 were written.
InnoDB: Operating system error number 112.
InnoDB: Check that your OS and file system support files of this size.
InnoDB: Check also that the disk is not full or a disk quota exceeded.
InnoDB: Error number 112 means 'Unknown error'.
InnoDB: Some operating system error numbers are described at
InnoDB: http://dev.mysql.com/doc/refman/5.5/en/operating-system-error-codes.html
InnoDB: Error in creating C:\PROGRA~3\Themler\db_data\ib_logfile1: probably out of disk space
160719 12:56:46 [ERROR] Plugin 'InnoDB' init function returned error.
160719 12:56:46 [ERROR] Plugin 'InnoDB' registration as a STORAGE ENGINE failed.
160719 12:56:46 [ERROR] Unknown/unsupported storage engine: InnoDB
160719 12:56:46 [ERROR] Aborting
160719 12:56:46 [Note] C:\Program Files (x86)\Themler\bin\mysql\bin\mythemlerd.exe: Shutdown complete
160719 12:57:01 [Note] Plugin 'FEDERATED' is disabled.
160719 12:57:01 InnoDB: The InnoDB memory heap is disabled
160719 12:57:01 InnoDB: Mutexes and rw_locks use Windows interlocked functions
160719 12:57:01 InnoDB: Compressed tables use zlib 1.2.3
160719 12:57:01 InnoDB: Initializing buffer pool, size = 256.0M
160719 12:57:01 InnoDB: Completed initialization of buffer pool
InnoDB: Error: space header page consists of zero bytes in data file C:\PROGRA~3\Themler\db_data\ibdata1
160719 12:57:01 InnoDB: Could not open or create data files.
160719 12:57:01 InnoDB: If you tried to add new data files, and it failed here,
160719 12:57:01 InnoDB: you should now edit innodb_data_file_path in my.cnf back
160719 12:57:01 InnoDB: to what it was, and remove the new ibdata files InnoDB created
160719 12:57:01 InnoDB: in this failed attempt. InnoDB only wrote those files full of
160719 12:57:01 InnoDB: zeros, but did not yet use them in any way. But be careful: do not
160719 12:57:01 InnoDB: remove old data files which contain your precious data!
160719 12:57:01 [ERROR] Plugin 'InnoDB' init function returned error.
160719 12:57:01 [ERROR] Plugin 'InnoDB' registration as a STORAGE ENGINE failed.
160719 12:57:01 [ERROR] Unknown/unsupported storage engine: InnoDB
160719 12:57:01 [ERROR] Aborting
160719 12:57:01 [Note] C:\Program Files (x86)\Themler\bin\mysql\bin\mythemlerd.exe: Shutdown complete
160719 12:57:17 [Note] Plugin 'FEDERATED' is disabled.
160719 12:57:17 InnoDB: The InnoDB memory heap is disabled
160719 12:57:17 InnoDB: Mutexes and rw_locks use Windows interlocked functions
160719 12:57:17 InnoDB: Compressed tables use zlib 1.2.3
160719 12:57:17 InnoDB: Initializing buffer pool, size = 256.0M
160719 12:57:18 InnoDB: Completed initialization of buffer pool
160719 12:57:18 InnoDB: Could not open or create data files.
160719 12:57:18 InnoDB: If you tried to add new data files, and it failed here,
160719 12:57:18 InnoDB: you should now edit innodb_data_file_path in my.cnf back
160719 12:57:18 InnoDB: to what it was, and remove the new ibdata files InnoDB created
160719 12:57:18 InnoDB: in this failed attemp
l have a problem like this INFO:Version files finded: INFO: C:\PROGRA~3\Themler\1.0.319.25.ver INFO:Check free disk space... INFO:Check Services... ERROR:MySQL service isn't started INFO:Check Files... INFO:Check HTTP Server... INFO:Check url for C:\PROGRA~3\Themler\hd_data\themler_4052686469 INFO: Check is url available: http://localhost:12080/themler_4052686469/startup INFO:Check INI Files... INFO:No errors! ======== Content of file C:\Program Files (x86)\Themler\bin\_logs\bat_exec.log ======== Program files detected C:\Program Files (x86) Must be on program files\themler\bin C s�r�c�s�ndeki birimin etiketi yok. Birim Seri Numaras�: 08B6-9391 C:\Program Files (x86)\Themler\bin dizini 19.07.2016 12:56 &lt;dir&gt; . 19.07.2016 12:56 &lt;dir&gt; .. 19.07.2016 12:56 &lt;dir&gt; 7zip 19.07.2016 12:56 &lt;dir&gt; apache 19.07.2016 12:56 &lt;dir&gt; diagnostics 22.06.2016 15:18 1.402 install-apache.bat 22.06.2016 15:18 2.724 install-mysql.bat 19.07.2016 12:56 &lt;dir&gt; mysql 19.07.2016 12:56 &lt;dir&gt; php 22.06.2016 15:18 1.730 uninstall-apache.bat 22.06.2016 15:18 1.695 uninstall-mysql.bat 19.07.2016 12:56 &lt;dir&gt; _logs &lt;/dir&gt;&lt;/dir&gt;&lt;/dir&gt;&lt;/dir&gt;&lt;/dir&gt;&lt;/dir&gt;&lt;/dir&gt;&lt;/dir&gt; 4 Dosya 7.551 bayt 8 Dizin 434.905.088 bayt bo� creating logs just in case C:\ProgramData\Themler alt dizini ya da dosyas� halen var. C:\ProgramData\Themler\logs alt dizini ya da dosyas� halen var. Cr Program files detected C:\Program Files (x86) Must be on program files\themler\bin C s�r�c�s�ndeki birimin etiketi yok. Birim Seri Numaras�: 08B6-9391 C:\Program Files (x86)\Themler\bin dizini 19.07.2016 12:56 &lt;dir&gt; . 19.07.2016 12:56 &lt;dir&gt; .. 19.07.2016 12:56 &lt;dir&gt; 7zip 19.07.2016 12:56 &lt;dir&gt; apache 19.07.2016 12:56 &lt;dir&gt; diagnostics 22.06.2016 15:18 1.402 install-apache.bat 22.06.2016 15:18 2.724 install-mysql.bat 19.07.2016 12:56 &lt;dir&gt; mysql 19.07.2016 12:56 &lt;dir&gt; php 22.06.2016 15:18 1.730 uninstall-apache.bat 22.06.2016 15:18 1.695 uninstall-mysql.bat 19.07.2016 13:00 &lt;dir&gt; _logs &lt;/dir&gt;&lt;/dir&gt;&lt;/dir&gt;&lt;/dir&gt;&lt;/dir&gt;&lt;/dir&gt;&lt;/dir&gt;&lt;/dir&gt; 4 Dosya 7.551 bayt 8 Dizin 1.060.290.560 bayt bo� creating logs just in case C:\ProgramData\Themler alt dizini ya da dosyas� halen var. C:\ProgramData\Themler\logs alt dizini ya da dosyas� halen var. Cr ======== End of file C:\Program Files (x86)\Themler\bin\_logs\bat_exec.log ======== ERROR:Unable to find file C:\ProgramData\Themler\logs\Themler_vbs.log ERROR:Unable to find file C:\Users\Murat\AppData\Local\Themler\Themler_vbs.log ======== Content of file C:\ProgramData\Themler\logs\startup.php.log ======== Tue, 19 Jul 2016 10:00:57 +0000 run from browser = suffix = _4052686469 themlerDataPath = C:/ProgramData/Themler icPath = C:/ProgramData/Themler/hd_data/themler_4052686469 url = http://127.0.0.1:12080/themler_4052686469 versionFile not exists UnZip successful, target directory exists Replace common.php result is 3930 ======== End of file C:\ProgramData\Themler\logs\startup.php.log ======== ======== Content of file C:\ProgramData\Themler\logs\apache\error.log ======== AH00558: hthemlerd.exe: Could not reliably determine the server's fully qualified domain name, using fe80::703b:6e2c:c9a8:7145. Set the 'ServerName' directive globally to suppress this message [Tue Jul 19 13:00:54.529296 2016] [mpm_winnt:notice] [pid 2568:tid 720] AH00455: Apache/2.4.16 (Win32) PHP/5.4.42 configured -- resuming normal operations [Tue Jul 19 13:00:54.541015 2016] [mpm_winnt:notice] [pid 2568:tid 720] AH00456: Server built: Jul 13 2015 10:37:15 [Tue Jul 19 13:00:54.541015 2016] [core:notice] [pid 2568:tid 720] AH00094: Command line: 'C:\\Program Files (x86)\\Themler\\bin\\apache\\bin\\hthemlerd.exe -d C:/Program Files (x86)/Themler/bin/apache' [Tue Jul 19 13:00:54.551757 2016] [mpm_winnt:notice] [pid 2568:tid 720] AH00418: Parent: Created child process 1688 AH00558: hthemlerd.exe: Could not reliably determine the server's fully qualified domain name, using fe80::703b:6e2c:c9a8:7145. Set the 'ServerName' directive globally to suppress this message AH00558: hthemlerd.exe: Could not reliably determine the server's fully qualified domain name, using fe80::703b:6e2c:c9a8:7145. Set the 'ServerName' directive globally to suppress this message [Tue Jul 19 13:00:55.203125 2016] [mpm_winnt:notice] [pid 1688:tid 668] AH00354: Child: Starting 64 worker threads. ======== End of file C:\ProgramData\Themler\logs\apache\error.log ======== ======== Content of file C:\ProgramData\Themler\logs\apache\access.log ======== ::1 - - [19/Jul/2016:13:07:15 +0300] "GET /themler_4052686469/startup HTTP/1.1" 301 258 35157 mis ::1 - - [19/Jul/2016:13:07:15 +0300] "GET /themler_4052686469/startup/ HTTP/1.1" 200 30311 1174805 mis ::1 - - [19/Jul/2016:13:07:28 +0300] "GET /themler_4052686469/startup HTTP/1.1" 301 258 0 mis ::1 - - [19/Jul/2016:13:07:28 +0300] "GET /themler_4052686469/startup/ HTTP/1.1" 200 30311 1355469 mis ::1 - - [19/Jul/2016:13:07:47 +0300] "GET /themler_4052686469/startup HTTP/1.1" 301 258 0 mis ::1 - - [19/Jul/2016:13:07:47 +0300] "GET /themler_4052686469/startup/ HTTP/1.1" 200 30311 1944336 mis ::1 - - [19/Jul/2016:13:08:20 +0300] "GET /themler_4052686469/startup HTTP/1.1" 301 258 0 mis ::1 - - [19/Jul/2016:13:08:20 +0300] "GET /themler_4052686469/startup/ HTTP/1.1" 200 30311 1364258 mis ::1 - - [19/Jul/2016:13:10:52 +0300] "GET /themler_4052686469/startup HTTP/1.1" 301 258 0 mis ::1 - - [19/Jul/2016:13:10:52 +0300] "GET /themler_4052686469/startup/ HTTP/1.1" 200 30311 1560547 mis ::1 - - [19/Jul/2016:14:41:40 +0300] "GET /themler_4052686469/startup HTTP/1.1" 301 258 169922 mis ::1 - - [19/Jul/2016:14:41:40 +0300] "GET /themler_4052686469/startup/ HTTP/1.1" 200 30311 1877930 mis ::1 - - [19/Jul/2016:14:43:10 +0300] "GET /themler_4052686469/startup HTTP/1.1" 301 258 977 mis ::1 - - [19/Jul/2016:14:43:10 +0300] "GET /themler_4052686469/startup/ HTTP/1.1" 200 30311 377930 mis ::1 - - [19/Jul/2016:14:43:20 +0300] "GET /themler_4052686469/startup HTTP/1.1" 301 258 977 mis ::1 - - [19/Jul/2016:14:43:20 +0300] "GET /themler_4052686469/startup/ HTTP/1.1" 200 30311 379883 mis ::1 - - [19/Jul/2016:18:23:31 +0300] "GET /themler_4052686469/startup HTTP/1.1" 301 258 774414 mis ======== End of file C:\ProgramData\Themler\logs\apache\access.log ======== ======== Content of file C:\ProgramData\Themler\logs\mysql\error.log ======== InnoDB: 1048576 bytes should have been written, only 0 were written. InnoDB: Operating system error number 112. InnoDB: Check that your OS and file system support files of this size. InnoDB: Check also that the disk is not full or a disk quota exceeded. InnoDB: Error number 112 means 'Unknown error'. InnoDB: Some operating system error numbers are described at InnoDB: http://dev.mysql.com/doc/refman/5.5/en/operating-system-error-codes.html InnoDB: Error in creating C:\PROGRA~3\Themler\db_data\ib_logfile1: probably out of disk space 160719 12:56:46 [ERROR] Plugin 'InnoDB' init function returned error. 160719 12:56:46 [ERROR] Plugin 'InnoDB' registration as a STORAGE ENGINE failed. 160719 12:56:46 [ERROR] Unknown/unsupported storage engine: InnoDB 160719 12:56:46 [ERROR] Aborting 160719 12:56:46 [Note] C:\Program Files (x86)\Themler\bin\mysql\bin\mythemlerd.exe: Shutdown complete 160719 12:57:01 [Note] Plugin 'FEDERATED' is disabled. 160719 12:57:01 InnoDB: The InnoDB memory heap is disabled 160719 12:57:01 InnoDB: Mutexes and rw_locks use Windows interlocked functions 160719 12:57:01 InnoDB: Compressed tables use zlib 1.2.3 160719 12:57:01 InnoDB: Initializing buffer pool, size = 256.0M 160719 12:57:01 InnoDB: Completed initialization of buffer pool InnoDB: Error: space header page consists of zero bytes in data file C:\PROGRA~3\Themler\db_data\ibdata1 160719 12:57:01 InnoDB: Could not open or create data files. 160719 12:57:01 InnoDB: If you tried to add new data files, and it failed here, 160719 12:57:01 InnoDB: you should now edit innodb_data_file_path in my.cnf back 160719 12:57:01 InnoDB: to what it was, and remove the new ibdata files InnoDB created 160719 12:57:01 InnoDB: in this failed attempt. InnoDB only wrote those files full of 160719 12:57:01 InnoDB: zeros, but did not yet use them in any way. But be careful: do not 160719 12:57:01 InnoDB: remove old data files which contain your precious data! 160719 12:57:01 [ERROR] Plugin 'InnoDB' init function returned error. 160719 12:57:01 [ERROR] Plugin 'InnoDB' registration as a STORAGE ENGINE failed. 160719 12:57:01 [ERROR] Unknown/unsupported storage engine: InnoDB 160719 12:57:01 [ERROR] Aborting 160719 12:57:01 [Note] C:\Program Files (x86)\Themler\bin\mysql\bin\mythemlerd.exe: Shutdown complete 160719 12:57:17 [Note] Plugin 'FEDERATED' is disabled. 160719 12:57:17 InnoDB: The InnoDB memory heap is disabled 160719 12:57:17 InnoDB: Mutexes and rw_locks use Windows interlocked functions 160719 12:57:17 InnoDB: Compressed tables use zlib 1.2.3 160719 12:57:17 InnoDB: Initializing buffer pool, size = 256.0M 160719 12:57:18 InnoDB: Completed initialization of buffer pool InnoDB: Error: space header page consists of zero bytes in data file C:\PROGRA~3\Themler\db_data\ibdata1 160719 12:57:18 InnoDB: Could not open or create data files. 160719 12:57:18 InnoDB: If you tried to add new data files, and it failed here, 160719 12:57:18 InnoDB: you should now edit innodb_data_file_path in my.cnf back 160719 12:57:18 InnoDB: to what it was, and remove the new ibdata files InnoDB created 160719 12:57:18 InnoDB: in this failed attemp
Support Team posted this 19 July 2016
6. Download latest version of Themler for Windows from themler.com, install it and try to start with any CMS and create a theme.
Hello, Please follow the steps below: 1. Backup all theme folders somewhere on your computer. 2. Uninstall Themler completely and also check the box for "Remove all CMS content". 3. Check if the following folders are still present: C:\Program Files (x86)\Themler C:\ProgramData\Themler 4. If they exist, remove them. 5. Reboot the machine after uninstalling Themler, so that all Themler services are removed for sure. 6. Download latest version of Themler for Windows from themler.com, install it and try to start with any CMS and create a theme. Please let us know the result. Sincerely, Nettie, BillionDigital Team
