i can not find blog plugin for joomla. i used blog plugin two months ago but now this plugin only html.
This Plugin:
This Plugin:
You have provided a link to the layout sections. They can be used in any template, not only HTML. If you want to apply a Blog section to your theme, you need to open Blog template, navigate to the Home tab and choose Change Blog option on the left in the top ribbon.
Hi Team, what is preventing you implement this an all templates, even custom ?
Hi Team, what is preventing you implement this an all templates, even custom ?Hi,
What for you need blog layouts in other templates that do not support blog layout? Or you are talking about the different things?
I am talking about "Change blog layout" button. You said in one other topic it works to 100% only on Blog template ?
I am talking about "Change blog layout" button. You said in one other topic it works to 100% only on Blog template ?Hi,
Yes, it works on the Blog page as that is the only place where Blog layout is used. You mean to enable such option in each Posts control on all other templates? I'm not sure that it will be correct. On the Page template for example, there are Posts Presets that do correspond to the Page view.
But OK, make it works on all templates. Why not ? It is very good thing and Users can share own Post Blog layouts with time.
Cannot talk for other people but I never use Blog template. Find it very limited, as you can use only one in Theme Options.
But OK, make it works on all templates. Why not ? It is very good thing and Users can share own Post Blog layouts with time. Cannot talk for other people but I never use Blog template. Find it very limited, as you can use only one in Theme Options.Hello Stagger Lee,
the Themler themes are working in such way that Joomla blog could be output via Home or Blog template.
If there's a page which is displayed with lets say Page Template and then you update its menu link in Joomla and set it to Category Blog then template of this page would be changed to Blog automatically.
And I'll pass your suggestion about pre-built Blog layouts to developers team
I meant for WordPress, dont use Joomla.
I meant for WordPress, dont use Joomla.Hi,
I'm sorry for the inconvenience, actually for the WP is the same.
Hi, I'm sorry for the inconvenience, actually for the WP is the same. Aileen
