If I want a beginning theme that will have a center section with two sidebars what is the proper starting theme layout?
Is it a theme with 3 columns or a theme with a single column in the center and sidebars activated that can be modified to add more columns as the need arises?
Even more technical is where can I find any document that tells me the steps to set up a new theme. When there are columns, sidebars, menus, headers, etc. a lot of time and support questions could be saved if there were a step by step initial setup guide. For example: when sidebars are in the plan when do I activate those and how. Once sidebars are activated is that a setting that affects every page or can this be selected on a page by page basis?
There are so many options for controlling theme appearance and function that it is difficult to know where to start.
If I want a beginning theme that will have a center section with two sidebars what is the proper starting theme layout? Is it a theme with 3 columns or a theme with a single column in the center and sidebars activated that can be modified to add more columns as the need arises? Even more technical is where can I find any document that tells me the steps to set up a new theme. When there are columns, sidebars, menus, headers, etc. a lot of time and support questions could be saved if there were a step by step initial setup guide. For example: when sidebars are in the plan when do I activate those and how. Once sidebars are activated is that a setting that affects every page or can this be selected on a page by page basis? There are so many options for controlling theme appearance and function that it is difficult to know where to start.
