Add a vertical menu in themler for joomla
maillard.jul
maillard.jul posted this 20 July 2016
Hello, I'm trying to add a vertical menu in themler for my website that already have a main horizontal menu.
In fact i would like to link them but anyways.. i cant find how to add a vertical menu...
Is it posible to do so ?
Julien
Hello, I'm trying to add a vertical menu in themler for my website that already have a main horizontal menu. In fact i would like to link them but anyways.. i cant find how to add a vertical menu... Is it posible to do so ? Thanks Julien
13 Comments
Support Team posted this 20 July 2016
Hi Julien,
Please check the following article:
http://answers.themler.com/articles/6643/how-to-create-vertical-menus-in-joomla
You may find it really helpful.
Let us know if you have any further questions.
Ivan
Hi Julien, Please check the following article: http://answers.themler.com/articles/6643/how-to-create-vertical-menus-in-joomla You may find it really helpful. Let us know if you have any further questions. Thanks, Ivan
maillard.jul
Its not possible to do it in themler ?
Thank you Its not possible to do it in themler ?
Probably, the article doesn't completely describe the whole process.
So you firstly need to add a Joomla Module Position control (or you can use Left Sidebar with left Joomla position in it) in Themler, then go to your Joomla admin, create a new module and assign it to that position.
And then add this vmenusuffix as described in the mentioned article.
Ivan
Hi, Probably, the article doesn't completely describe the whole process. So you firstly need to add a Joomla Module Position control (or you can use Left Sidebar with **left** Joomla position in it) in Themler, then go to your Joomla admin, create a new module and assign it to that position. And then add this ` vmenu`suffix as described in the mentioned article. Thanks, Ivan
maillard.jul
maillard.jul posted this 21 July 2016
Ok it worked, thank u very much!
Support Team posted this 21 July 2016
You are welcome! Please feel free to contact us in any other case. Sincerely, Nettie, BillionDigital Team
DaveOzric
DaveOzric posted this 23 July 2016
Now can you please make the vertical menus responsive as well. I know how to make a horizontal menu vertical using some various settings but I don't understand why all menus don't go responsive when needed.
Please add this feature.
Now can you please make the vertical menus responsive as well. I know how to make a horizontal menu vertical using some various settings but I don't understand why all menus don't go responsive when needed. Please add this feature.
maillard.jul
maillard.jul posted this 24 July 2016
I have a another issue with my v menu, i would like it to be justified.. but it doesnt work... if my menu item are too long then it goes into my article... i would like to avoid that! any clue ?
Julien
I have a another issue with my v menu, i would like it to be justified.. but it doesnt work... if my menu item are too long then it goes into my article... i would like to avoid that! any clue ? Thanks Julien
Support Team posted this 25 July 2016
DaveOzric,
At the moment the Vertical Menu cannot be minimized into a button in responsive like Horizontal Menu this behaviour is not supported by Bootstrap. Our developers will investigate other possible solutions for the Vertical Menu in responsive, most probably there will be an option to make it a vertical panel.
**DaveOzric**, At the moment the Vertical Menu cannot be minimized into a button in responsive like Horizontal Menu this behaviour is not supported by Bootstrap. Our developers will investigate other possible solutions for the Vertical Menu in responsive, most probably there will be an option to make it a vertical panel. Sincerely, Nettie, BillionDigital Team
maillard.jul,
We are sorry for the issue. I have forwarded it to our developers.
**maillard.jul**, We are sorry for the issue. I have forwarded it to our developers. Sincerely, Nettie, BillionDigital Team
Stagger Lee posted this 25 July 2016
Dave, it is so easy. While you wait for this implemented do this:
  • Insert standard horizontal menu instead of vertical. Don mind mess it makes for now.
  • Give all menu items (Ul, Li too) 100% width, display:block. Remove paddings, margins.
  • Continue to style as you wish, and there is your responsive vertical menu.
Sorry, missed part of horizontal. Let it be here for other Users.
Menu is menu, just collection of CSS rules.
> Now can you please make the vertical menus responsive as well. I know how to make a horizontal menu vertical using some various settings but I don't understand why all menus don't go responsive when needed. > > Please add this feature. Dave, it is so easy. While you wait for this implemented do this: - Insert standard horizontal menu instead of vertical. Don mind mess it makes for now. - Give all menu items (Ul, Li too) 100% width, display:block. Remove paddings, margins. - Continue to style as you wish, and there is your responsive vertical menu. Sorry, missed part of horizontal. Let it be here for other Users. Menu is menu, just collection of CSS rules.
lucydawson
lucydawson posted this 18 June 2025
I found the step-by-step guidance really helpful—especially the reminder to add a Joomla Module Position (or use the Left Sidebar) in Themler before assigning the menu module, then applying the vmenu class suffix in Joomla. That tip alone cleared up several of my past frustrations when styling vertical menus. Also, recommending the “Apply theme to CMS” step ensures your styling actually shows up—great attention to detail. For anyone juggling tech projects alongside heavier coursework, aligning this kind of practical walkthrough with clear structure reminds me of how I approach management assignment help breaking things into logical, actionable steps makes a world of difference.
I found the step-by-step guidance really helpful—especially the reminder to add a Joomla Module Position (or use the Left Sidebar) in Themler before assigning the menu module, then applying the vmenu class suffix in Joomla. That tip alone cleared up several of my past frustrations when styling vertical menus. Also, recommending the “Apply theme to CMS” step ensures your styling actually shows up—great attention to detail. For anyone juggling tech projects alongside heavier coursework, aligning this kind of practical walkthrough with clear structure reminds me of how I approach [management assignment help][1] breaking things into logical, actionable steps makes a world of difference. [1]: https://www.nativeassignmenthelp.com/management-assignment-help
ExamsVCE
ExamsVCE posted this 30 September 2025
We have a long list of satisfied customers from multiple countries. Our Microsoft MS-102 practice questions will certainly assist you to get passing marks on the first attempt. MS-102 PDF and Practice Test PDF Questions and Practice Test ClapGeek offers Microsoft MS-102 PDF questions, web-based and desktop practice tests that are consistently updated.
Click Now >>> https://www.clapgeek.com/MS-102-exam.html
We have a long list of satisfied customers from multiple countries. Our Microsoft MS-102 practice questions will certainly assist you to get passing marks on the first attempt. MS-102 PDF and Practice Test PDF Questions and Practice Test ClapGeek offers Microsoft MS-102 PDF questions, web-based and desktop practice tests that are consistently updated. Click Now >>> [https://www.clapgeek.com/MS-102-exam.html][1] [1]: https://www.clapgeek.com/MS-102-exam.html
mejov57740
mejov57740 posted this 29 October 2025
A vertical menu may provide a simple and organized way to navigate through different sections of a website or app, making it easier for users to find what they need without confusion. There could be a chance that this design helps create a cleaner layout and improves user experience. It’s possible that Hardee’s breakfast time details could appear more clearly within such a layout, allowing customers to explore menu options with ease and maybe enjoy their meals at a time that suits them best.
A vertical menu may provide a simple and organized way to navigate through different sections of a website or app, making it easier for users to find what they need without confusion. There could be a chance that this design helps create a cleaner layout and improves user experience. It’s possible that [Hardee’s breakfast time][1] details could appear more clearly within such a layout, allowing customers to explore menu options with ease and maybe enjoy their meals at a time that suits them best. [1]: https://hardeesbreakfasthours.org/
