prestashop 1.6.1.6
Each themler theme causes the error 500 and many other errors. after installing the theme you will still need time to install the whole shop
prestashop 1.6.1.6
Themes do work fine with the Prestashop 1.6.1.6.
Please follow the recommendations:
http://answers.themler.com/articles/65488/troubleshooting-read-first
http://answers.themler.com/articles/65524/themler-themes-issues-prestashop
Let us know if that helps.
I use "Shopit"
On the home page is an error 500:
conf :
disabled overrides
themler module enabled
Please follow these steps:
Buongiorno,
mi unisco alla conversazione, anche a me non funzionano i temi di prestashop su la versione 1.6.1.6
provato tutte le soluzioni proposte ma senza risultato
Please create a separate Private topic and provide the access to the PrestaShop admin panel.
Buonasera
Anch'io riscontro problemi... Themler in modalità desktop funziona ma una volta caricato il Template su prestashop 1.6.1.6 non si riesce più a modificare, il pannello modifica funziona ma la visione delle pagine è tutta sballata.
Please go to Prestashop admin >> Advanced Parameters >> Performance and change "Template Compilation" to option 2 or 3:
http://answers.themler.com/articles/3829/how-to-use-prestashop-theme#features_of_using
The fact is that after installation of new Prestashop version the option "Never recompile template files" is set by default, and that causes the issues.
If this does not help. please also follow suggestions from the articles listed above. If the issue is still present, please create a new private topic and provide temporary access to your website for investigation.
hi,
I have similar issue,
after Presta update from 1.6.1.1 to 1.6.1.6
in Chrome: themler is restarting constantly,
in Firefox: themler is loading eternally
Have done all fixes in this post with no success,
what next?
Krasy,
site is on ssl,
using thermler without ssl,
caused crash,
thx for support.
The reason for the problems is that the "Never recompile template files" option is set by default after installing the latest version of Prestashop. If none of this is helpful.
SEO Agency
