Hello, I am not able to save changes in joomla 2.5.28 template settings like productslider, title, slogan etc. because the Buttons on top are missing.
Whats wrong? Please advice.
best regards
Jens
best regards
Jens
Hello Jens,
Thank you, I could reproduce the issue (with Joomla 2.5 but not with Joomla 3+) and have forwarded it to our developers.
Hi, thanks for the quick reply. I can confirm that I have only the issue with 2.5. On 3 it works.
regards
Jens
Hi, thanks for the quick reply. I can confirm that I have only the issue with 2.5. On 3 it works. regards JensHello Jens,
I have discussed the issue with our developers. The fact is that Joomla 2.5 support has stopped last year:
http://developer.joomla.org/development-status.html
Quite possibly, some other controls may also have compatibility issues with Joomla 2.5.
So currently our development team is concentrated on improving Themler for Joomla 3+.
Sorry for this.
We would recommend you to try Themler with Joomla 3+ as soon as it is possible for you.
Hello Nettie, thanks for the information. I know that Joomla team stopped the support for the last LTR Version. But the problem is, that a lot of things are not working in a propper way in J3. This is also the reason why the virtuemart team has provides only a J2.5+VM Bundle. Further a lot of extensions have trouble with the new J3.
So is there a workaround which I can use to configure the product slider?
thank you in advanced!
best regards
Jens
Hello Nettie, thanks for the information. I know that Joomla team stopped the support for the last LTR Version. But the problem is, that a lot of things are not working in a propper way in J3. This is also the reason why the virtuemart team has provides only a J2.5+VM Bundle. Further a lot of extensions have trouble with the new J3. So is there a workaround which I can use to configure the product slider? thank you in advanced! best regards JensHello Jens,
Please try this workaround:
Find this code:
// instantiate the frontend application.
JFactory::$application = JApplication::getInstance('administrator');
And replace it to:
CustomModuleHelper::clean();
2.Then please find the file {ThemeName}/app/CustomModuleHelper.php in the theme folder.
Find this code:
<?php
class CustomModuleHelper extends JModuleHelper {}
And replace it to:
<?php
public static function clean() {
$modules = & JModuleHelper::_load();
$modules = null;
This should help.
Best regards,
