PLEASE HELP - PROBLEM WITH RESPONSIVE IMAGES
claudiawhittakerdesigns
claudiawhittakerdesigns posted this 27 July 2016
Hi there,
It would be great if someone could advise me - I have always used wordpress but decided to give themler a shot and use it from scratch
I designed a site using themler which has many pics in it. It is fine for laptops and tablets - however the pics go everywhere / missing when it comes to viewing it on a cellphone.
Esepcially the 'equipment sales tab'.
As well as the way the menu responds is not ideal.
Any help would be great!
Here is the site :
www.earthquip.com
Many thanks,
Claudia
Hi there, It would be great if someone could advise me - I have always used wordpress but decided to give themler a shot and use it from scratch I designed a site using themler which has many pics in it. It is fine for laptops and tablets - however the pics go everywhere / missing when it comes to viewing it on a cellphone. Esepcially the 'equipment sales tab'. As well as the way the menu responds is not ideal. Any help would be great! Here is the site : www.earthquip.com Many thanks, Claudia
Support Team posted this 27 July 2016
Hello Claudia,
when adding images use option Enable Responsive under Image Options
You may also follow the article http://answers.themler.com/articles/6460/how-ro-resize-slider-images-and-text-in-responsive-mode
Responsive menu.
1.switch to Phone mode;
2.select Horizontal Menu control and make sure that its Height property is empty
3.change color or background color of the active menu item
Hello Claudia, when adding images use option Enable Responsive under Image Options !RespImages.png! You may also follow the article http://answers.themler.com/articles/6460/how-ro-resize-slider-images-and-text-in-responsive-mode Responsive menu. 1.switch to Phone mode; 2.select Horizontal Menu control and make sure that its Height property is empty 3.change color or background color of the active menu item regards, Aileen
claudiawhittakerdesigns posted this 28 July 2016
Thank you for your quick response Aileen, I will give this a try and let you know if I come right.
1 question ) why do I need to change the colour of menu? I would like it to stay the same colour across all platforms but just be responsive to the relative platform.
Thank you for your quick response Aileen, I will give this a try and let you know if I come right. 1 question ) why do I need to change the colour of menu? I would like it to stay the same colour across all platforms but just be responsive to the relative platform.
So I did this...and my images went missing and all over the place!
I am going to start again... please explain the best option for inserting multiple images to a page..so that it works across all platforms... how do I go about it?
3 per row...12 on a page.
So I did this...and my images went missing and all over the place! I am going to start again... please explain the best option for inserting multiple images to a page..so that it works across all platforms... how do I go about it? 3 per row...12 on a page.
Support Team posted this 28 July 2016
Hello Claudia,
1.there's no need to change the menu color, it was just an example.
2.to insert 12 images into the page add Image control from Insert tab >> select Image and drag it to the position where you'd like it to be located on the page. Follow this procedure 12 times.
Hello Claudia, 1.there's no need to change the menu color, it was just an example. 2.to insert 12 images into the page add Image control from Insert tab >> select Image and drag it to the position where you'd like it to be located on the page. Follow this procedure 12 times. regards, Aileen
