Position in Themler
hongseoxanh
hongseoxanh posted this 29 July 2016
I am using joomla templates themler to create, I want to ask is how to create one position and took the pictures available in stock inserting. I want to first selected item to 1 position. Looking forward to support.
enter image description here
I am using joomla templates themler to create, I want to ask is how to create one position and took the pictures available in stock inserting. I want to first selected item to 1 position. Looking forward to support. ![enter image description here][1] [1]: http://127.0.0.1:12080/themler_74550059/joomla/images/images.png
Support Team posted this 29 July 2016
I'm sorry, but your description is not clear. Could you please explain in more details. Also the image was not attached to the case, please try to upload once again.
Hi, I'm sorry, but your description is not clear. Could you please explain in more details. Also the image was not attached to the case, please try to upload once again. Sincerely, Hella
hongseoxanh
  1. I would like to ask is when creating the finished position how do I use the imagery available in themler to insert always in my position just created. (attached file)
    Example: Insert a photo slide module running on the newly created position
  2. The images I create in governance san when I do not know where it is, look in the module does not have and did not see artice.
1. I would like to ask is when creating the finished position how do I use the imagery available in themler to insert always in my position just created. (attached file) Example: Insert a photo slide module running on the newly created position 2. The images I create in governance san when I do not know where it is, look in the module does not have and did not see artice.
Unfortunately I still not understand what you mean. Could you please try typing detailed questions in your native language and translate them using google translate.
Themler has "joomla position" control used to create Joomla module positions where you can insert any Joomla modules under the Joomla Module manager.
You cannot insert any other controls inside joomla position in Themler. This position if for joomla modules only.
I don't understand what images you're referring to and where you created them.
The anh2.png screenshot shows something similar to Slider module. if this is joomla module you can insert this module in the joomla position created using "joomla position" control.
This is the name of the module position:
The anh.png shows, if I understand correctly, a Themler Section. If this screenshot relates to #2 then, looks like, you inserted Section on the template.
There are two levels: template (blue and orange areas) and content (green area):
If you want to move this Section to the joomla article you should move it inside green area (by copy&paste).
Hi, Unfortunately I still not understand what you mean. Could you please try typing detailed questions in your native language and translate them using google translate. Themler has "joomla position" control used to create Joomla module positions where you can insert any Joomla modules under the Joomla Module manager. You cannot insert any other controls inside joomla position in Themler. This position if for joomla modules only. I don't understand what images you're referring to and where you created them. The **anh2.png** screenshot shows something similar to Slider module. if this is joomla module you can insert this module in the joomla position created using "joomla position" control. This is the name of the module position: !position-name.png! The **anh.png** shows, if I understand correctly, a Themler Section. If this screenshot relates to #2 then, looks like, you inserted Section on the template. There are two levels: template (blue and orange areas) and content (green area): !template-vs-content.png! If you want to move this Section to the joomla article you should move it inside green area (by copy&paste). Thank you, Olivia
hongseoxanh
hongseoxanh posted this 30 July 2016
Photo 1 is I developed position-8, 2 images are available in the data warehouse themler. I want to ask is how to add the item in photo 2 into position-8 was created in the image 1.
Support Team posted this 01 August 2016
Sections can not be added in the module positions. They can display only modules, added within the Joomla admin back end.
Hi, Sections can not be added in the module positions. They can display only modules, added within the Joomla admin back end. Sincerely, Hella
