Themler v.322 Beta Update (29-July-2016)
Support Team posted this 29 July 2016
Hi everyone,
We've released the new Themler Beta update.
The new version is 322.
Here is a list of fixes and features included in this Themler update:
UI
  • New Positioning dialog:
    We have removed "Align Content" extension and included its functionality into the updated "Positioning" dialog. Now there is only one option for alignment in different types of containers.
  • The Length modes have been renamed to Boxed/Wide/Fluid and the whole logic of this property has been redesigned.
    Also, we added Length option to Design tab. Now you can control the Layout of the current template in one click.
    The "Grid Padding" property from the theme Settings has been renamed to "Margins" and global "Margins" are now located on the Design tab next to the Length option.
General
We have tested Themler compatibility with:
  • PrestaShop 1.6.1.6 - no compatibility issues.
  • Joomla 3.6 - a few compatibility issues are fixed in this update. The issue with missing Print Icon will be fixed in the next update.
  • VirtueMart 3.0.17 - a few compatibility issues are fixed in this update. The issue with authorization screen will be fixed in the next update.
Fixes
General and UI
  • Fixed issue with controls (widget areas, etc) not removed after removing of the custom template where these controls were added.
  • Improved the Post Image, Product Image, etc. dialogs.
  • Fixed issue with converting Section height in em to px on resize.
  • Fixed issue with Table and Button properties under the More Styles.
  • Fixed crash with Mouse Wheel in Themler Settings.
  • Fixed issue with crash on uploading favicon "From File" on Themler Settings.
  • Other fixes and improvements.
Joomla & VirtueMart
  • Fixed compatibility issue with the most recent PHP 7 version (7.0.9).
  • Fixed issue with custom templates on Joomla 3.6.
  • Fixed issue with Products Slider and Product Variations.
  • Fixed issue with Product Variations and CloudZoom.
  • Fixed issue with customizing Store templates.
  • Fixed issue with Headline link.
  • Fixed issue with Products template when Page Layout option of the VM Category page is set to "Categories".
  • Other fixes.
WordPress & Woocommerce
  • Fixed issue with Proceed to checkout button on Woocommerce 2.6.
  • Fixed issue with YITH Subscriptions plug-in.
  • Fixed issue with installing Themler-Core plugin on some server configurations (HTTP Error 200 on save).
  • Added warning when* WordPress Address* and Site Address use different protocols - HTTP and HTTPS. This is the most common cause of Themler crash caused by cross-origin issue.
  • Reduced memory usage on Themler startup to solve out of memory problems in some cases:
    Allowed memory size of 134217728 bytes exhausted (tried to allocate 9529178 bytes)
  • Added warning when double bootstrap.js is found on the page.
  • A few other small fixes.
Drupal
  • Drupal 6: Fixed issue with accessing custom templates in Themler through the template list.
PrestaShop
  • Fixed issue with the multistore.
What Next?
  • MegaMenu is in process.
  • "Suggest Homepage" button like it was made in Artisteer
  • Ability to set large Header for the Home template and smaller Headers for other templates (only Intro part is visible). In this way, the large Slider will stay on the homepage only.
  • Ability to free-position any control to any exact place you like. It means that if there is no appropriate d'n'd layout position for control the absolute d'n'd position will appear (just like in Slider or Canvas).
Please find here more details on how to enable Beta Updates.
Themler Team
Hi everyone, We've released the new **Themler Beta** update. The new version is 322. Here is a list of fixes and features included in this Themler update: [post:91739] Please find [here](page:53794) more details on how to enable Beta Updates. Thank you, Themler Team
38 Comments
olivier2
olivier2 posted this 06 August 2016
Impossible to update. I always get this error :
Hello, Impossible to update. I always get this error : !322.png!
TJ Novick
TJ Novick posted this 06 August 2016
This update has screwed everything up. I was working on a Wordpress theme and had it just about ready to go live and I updated and now everything I had customized is gone. Wordpress footer widgets disappeared search box gone, blog layout reverted to original and my post disappeared, basically everything went away. I tried using the desktop application and when I created a new theme, it opened up my old site with all the content and not the default new theme that usually loads. Also I am not able to add sections or anything to a "page" but only to "template". Am not sure what the hell you all are doing but it was working fine and I am sure you fixed some bugs and added some suggestions but you created a whole new set of problems. Please lets get this resolved ASAP
joerg.cimen
joerg.cimen posted this 06 August 2016
I have the same problem.
> Hello, > Impossible to update. I always get this error : > ![](http://attachments.answers.billiondigital.com/906/17906/322.png) I have the same problem.
oceanite
oceanite posted this 06 August 2016
I have problems like TJ Novick in woocommerce: alignment columns, alignment text, bold text, themler is slow (Desktop).
I have problems like TJ Novick in woocommerce: alignment columns, alignment text, bold text, themler is slow (Desktop). Regards
TJ Novick
ok, everything is totally SCREWED UP. I go to a site I made earlier using desktop app, and there are no pages, only templates and it is showing content from the most recent theme I was working on. Boy this update just made me dead in the water. Any response from the admins? (crickets)
oceanite
try to test the previous version, I made this
> ok, everything is totally SCREWED UP. I go to a site I made earlier using desktop app, and there are no pages, only templates and it is showing content from the most recent theme I was working on. Boy this update just made me dead in the water. Any response from the admins? (crickets) try to test the previous version, I made this
TJ Novick
How do I get back to the previous non beta version?
> > ok, everything is totally SCREWED UP. I go to a site I made earlier using desktop app, and there are no pages, only templates and it is showing content from the most recent theme I was working on. Boy this update just made me dead in the water. Any response from the admins? (crickets) > > try to test the previous version, I made this How do I get back to the previous non beta version?
leonid2
leonid2 posted this 06 August 2016
Your prev project was backupped automatically before updating to the new Themler version. You can find it under the Open Project dialog on Desktop version. It has the same name as your project but with the number at the end. When you select it, it will be opened in prev Themler version.
> How do I get back to the previous non beta version? Your prev project was backupped automatically before updating to the new Themler version. You can find it under the Open Project dialog on Desktop version. It has the same name as your project but with the number at the end. When you select it, it will be opened in prev Themler version.
leonid2
I remember a few similar complaints on prev Themler versions too across this Forum, Could you please contact support and send them your corrupted project? I think that this will really help to find the problem and to fix it quickly.
> ok, everything is totally SCREWED UP. I go to a site I made earlier using desktop app, and there are no pages, only templates and it is showing content from the most recent theme I was working on. Boy this update just made me dead in the water. Any response from the admins? (crickets) I remember a few similar complaints on prev Themler versions too across this Forum, Could you please contact support and send them your corrupted project? I think that this will really help to find the problem and to fix it quickly.
TJ Novick
Ok I was able to locate previous version and when I opened it it was not the theme I was working on but rather the last theme I was working on. I tried opening all of the projects and they all opened the same last theme. This update really screwed things up or I have a corrupted file somewhere. I have asked support for serial number or activation or whatever I need and I was going to delete themler and reinstall, but they have not answered yet
> > How do I get back to the previous non beta version? > > Your prev project was backupped automatically before updating to the new Themler version. You can find it under the Open Project dialog on Desktop version. It has the same name as your project but with the number at the end. When you select it, it will be opened in prev Themler version. Ok I was able to locate previous version and when I opened it it was not the theme I was working on but rather the last theme I was working on. I tried opening all of the projects and they all opened the same last theme. This update really screwed things up or I have a corrupted file somewhere. I have asked support for serial number or activation or whatever I need and I was going to delete themler and reinstall, but they have not answered yet
leonid2
leonid2 posted this 07 August 2016
You don't need any serial number for reinstalling, but only the Billion Account that you've used to log in on this forum.
> I have asked support for serial number or activation or whatever I need and I was going to delete themler and reinstall, but they have not answered yet You don't need any serial number for reinstalling, but only the Billion Account that you've used to log in on this forum.
olivier2
olivier2 posted this 08 August 2016
Why do I have 328 instead of 322 ?
Why do I have 328 instead of 322 ?!2016-08-08-09-10-42-tao-6---Themler-for-WordPress.png!
Stagger Lee posted this 09 August 2016
Those are Beta versions. Deactivate it in your profile page here.
olivier2
olivier2 posted this 09 August 2016
Ok thank you
Ok thank you
Support Team posted this 09 August 2016
Hello Stagger Lee,
regarding the issue
Post Image - Extensions - Animation.
This issue has been resolved on our end and the fix is included into the next Themler update.
In the meantime as workaround remove the
float:left
of the Post Image control and animation works.
Hello Stagger Lee, regarding the issue > Post Image - Extensions - Animation. This issue has been resolved on our end and the fix is included into the next Themler update. In the meantime as workaround remove the float:left of the Post Image control and animation works. regards, Aileen
djundi
djundi posted this 10 August 2016
Some info about last update ? 3.2.8 ?
Stagger Lee posted this 10 August 2016
Hello Stagger Lee,
regarding the issue
float:left
I use v.328 and still same problem. This with float doesnt work.
> Hello Stagger Lee, > regarding the issue > > > Post Image - Extensions - Animation. > > This issue has been resolved on our end and the fix is included into the next Themler update. > In the meantime as workaround remove the > float:left > of the Post Image control and animation works. > > regards, > Aileen > I use v.328 and still same problem. This with float doesnt work.
Support Team posted this 12 August 2016
Hi Stagger Lee,
The animation works in v328 with float too. The problem is in order of elements:
first - Post Image,
then - Post Content
If you add a background to the Post Content you will see that it covers the Image and you cannot hover on it. This is normal behavior.
You need either remove floating or place the Post Image on Top of the Post Content with z-index.
Hi Stagger Lee, The animation works in v328 with float too. The problem is in order of elements: first - Post Image, then - Post Content If you add a background to the Post Content you will see that it covers the Image and you cannot hover on it. This is normal behavior. You need either remove floating or place the Post Image on Top of the Post Content with z-index. Thank you, Olivia
