Hello Olivia, thank you for your response.
Excuse me english
I did not explain myself well on my question.
I understand prestashop, I am not new to this.
I have successfully installed themler white theme, I have also installed Unidoo themes, etc. and everything worked well for me.
I have modified position of modules, added things with themler, modified menu .. etc .. and everything perfect!
Then I export when I complete modifications and import theme without themler, without themler billion modules.
(A problem that I have found, the top cart does not open javascript, the resizable button does not work, but this will be a problem with predesigned templates ... maybe, I do not know, this is not the problem that this question poses for me at the moment , but if you want to answer ....)
How do I edit the modified menu if the module?
Do I have to install a different module, another menu? because that can not be modified without the module billion ...
How do I edit the slider I have with themler?
I have to install another slider, because that is not configurable within pretashop modules ...
By the way, when installing blank template, the sample images of the theme are not for me, how can I see the images sample?
--- and so with the whole theme
It's as if only themler is a base to create a theme of its own, that's fine, but for everything to be easier, at least in prestashop, it would have themler to have a slider to edit etc ...
Gracias, Thank you,
Excuse me english
Gracias, Thank you,
