How do I add themler to my wordpress using Windows
sahebmhm
sahebmhm posted this 04 August 2016
Hello, I am very new to Wordpress, the wordpress is installed and themler is downloaded to my download directory as zip file name with name blank_themler_wordpress_theme.zip . How do I install (add) themler in Wordpress? Please help . I looked over internet but no luck!
Hello, I am very new to Wordpress, the wordpress is installed and themler is downloaded to my download directory as zip file name with name blank_themler_wordpress_theme.zip . How do I install (add) themler in Wordpress? Please help . I looked over internet but no luck! Thanks
Support Team posted this 05 August 2016
to install WP theme please follow the article http://answers.themler.com/articles/3624/how-to-install-wordpress-theme
Also as you're new to Themler I'd recommend that you refer to the articles from Getting Started section
http://answers.themler.com/categories/3909/getting-started
Hello, to install WP theme please follow the article http://answers.themler.com/articles/3624/how-to-install-wordpress-theme Also as you're new to Themler I'd recommend that you refer to the articles from Getting Started section http://answers.themler.com/categories/3909/getting-started Regards, Aileen
sahebmhm
sahebmhm posted this 05 August 2016
Hi Aileen,
Suppose I have downloaded the blank_themler_wordpress_theme.zip which is themler . And I have /wp-admin, wp-content, wp-includes to which of these folders should I unzip the blank_themler_wordpress_theme.zip ?
Or I tried to install it as theme or plugins but it was not recognized as either. Is that because I have to buy the $49 package? Thanks for helps.
Hi Aileen, Suppose I have downloaded the blank_themler_wordpress_theme.zip which is themler . And I have /wp-admin, wp-content, wp-includes to which of these folders should I unzip the blank_themler_wordpress_theme.zip ? Or I tried to install it as theme or plugins but it was not recognized as either. Is that because I have to buy the $49 package? Thanks for helps.
Support Team posted this 08 August 2016
have you tried to follow the article? It provides step by steps description for theme installation. Please follow it.
In fact Themler theme is installed in the same way as other WP themes
Hello, have you tried to follow the article? It provides step by steps description for theme installation. Please follow it. In fact Themler theme is installed in the same way as other WP themes regards, Aileen
sahebmhm
sahebmhm posted this 08 August 2016
Sorry, I am confused because I do not see the themler logo on the Wordpress Administration Panel, I think there is some kind of installation missing. All I have from themler is a folder with name untitled and subfolders of /content , export, fonts, images, includes, languages,library, plugins, preview, templates, woocommerce and some files which I do not how to work with these. Please bear with me.
Many thanks
Hi, Sorry, I am confused because I do not see the themler logo on the Wordpress Administration Panel, I think there is some kind of installation missing. All I have from themler is a folder with name untitled and subfolders of /content , export, fonts, images, includes, languages,library, plugins, preview, templates, woocommerce and some files which I do not how to work with these. Please bear with me. Many thanks
Support Team posted this 09 August 2016
I assume that you have followed the steps from the section "Install via Admin Panels (packed template)" of the article http://answers.themler.com/articles/3624/how-to-install-wordpress-theme
Right? Please let us know if not.
So the theme is installed but there's no Themler logo in Administration menu(panel). There may be two reasons:
1.the theme was saved without 'Include Themler..' option. In this case it cannot be opened in Themler anymore. In this case please re-download the theme and remember to enable the 'Include Themler...' option.
The install the theme again following the mentioned article.
2.You may not see the Themler admin Menu if you disabled Theme Editor for all users in the WP wp-config.php file by adding the following line:
define('DISALLOW_FILE_EDIT', true);
Please refer to to WP Codex https://codex.wordpress.org/Editing_wp-config.php#Disable_the_Plugin_and_Theme_Editor for more details.
Hello, I assume that you have followed the steps from the section "Install via Admin Panels (packed template)" of the article http://answers.themler.com/articles/3624/how-to-install-wordpress-theme Right? Please let us know if not. So the theme is installed but there's no Themler logo in Administration menu(panel). There may be two reasons: 1.the theme was saved without 'Include Themler..' option. In this case it cannot be opened in Themler anymore. In this case please re-download the theme and remember to enable the 'Include Themler...' option. The install the theme again following the mentioned article. 2.You may not see the Themler admin Menu if you disabled Theme Editor for all users in the WP wp-config.php file by adding the following line: define('DISALLOW_FILE_EDIT', true); Please refer to to WP Codex https://codex.wordpress.org/Editing_wp-config.php#Disable_the_Plugin_and_Theme_Editor for more details. regards, Aileen
sahebmhm
sahebmhm posted this 09 August 2016
I press add new theme then I see some theme with install option at the bottom . I do not know where themler themes are !
1- When I press install on the theme, I do not see the option for 'Include Themler' all I see is Successfully installed the theme .....
2- I did not have define('DISALLOWED_FILE_EDIT', true); but I added define('DISALLOWED_FILE_EDIT',false); to make sure.
FYI, I have plugin name wp Easy Uploader installed so I do not know if it has anything to do with that?
Is it possible to direct me to themler . zip or send me a test theme .zip
Hi, I press add new theme then I see some theme with install option at the bottom . I do not know where themler themes are ! 1- When I press install on the theme, I do not see the option for 'Include Themler' all I see is Successfully installed the theme ..... 2- I did not have define('DISALLOWED_FILE_EDIT', true); but I added define('DISALLOWED_FILE_EDIT',false); to make sure. FYI, I have plugin name wp Easy Uploader installed so I do not know if it has anything to do with that? Is it possible to direct me to themler . zip or send me a test theme .zip Thanks
Support Team posted this 10 August 2016
i see that you followed the steps 1-3 from the article successfully.
Lets try the next steps:
4. Choose "Upload".
5. Click the "Choose file" button to select the zip file from your computer and press "Install now".
At step 5 you need to select .zip file with Themler theme from your file system. You should have the zip file with downloaded theme.
Select it.
Then click "Install Now"
6.Click "Activate" to make the installed theme default.
Let us know the result. If you get a problem at any step please let us know at which one
Hello, i see that you followed the steps 1-3 from the article successfully. Lets try the next steps: *4. Choose "Upload". 5. Click the "Choose file" button to select the zip file from your computer and press "Install now".* !WPINstall1.png! At step 5 you need to select .zip file with Themler theme from your file system. You should have the zip file with downloaded theme. Select it. Then click "Install Now" !WPINstall2.png! *6.Click "Activate" to make the installed theme default.* Let us know the result. If you get a problem at any step please let us know at which one regards, Aileen
