Page (header) image
anneke
anneke posted this 30 March 2015
  1. Now I've got a slider on each page so every page has his own image.
I want to use the featured image from every page to show up in the header. But I can't place it there, because is has to be in the blog(I think). Isn't there a way to place it outside the blog module?
  1. Is there a way to place a video in the slider/head?
Thanks in advance,
Paul
Hi, 1. Now I've got a slider on each page so every page has his own image. I want to use the featured image from every page to show up in the header. But I can't place it there, because is has to be in the blog(I think). Isn't there a way to place it outside the blog module? 2. Is there a way to place a video in the slider/head? Thanks in advance, Paul
Support Team posted this 31 March 2015
Unfortunately Post Image can't be located outside the Blog control.
I've found a plug-in which creates a post featured image shortcode:
https://wordpress.org/plugins/add-post-thumbnail-shortcode/
You can add WP widget area control in Themler and then use this shortcode in the text widget in WP.
I've tested this plug-in on WP 3.8 on Themler's cloud. Looks like it works ok. Most probably this plug-in will work on WP 4.1.x too
You can insert youtube video by adding Video control (Insert >> other).
If you want some other video you can add WP Widget Area control and then insert Text widget with appropriate video code into this Widget Area in WP.
Hello > I want to use the featured image from every page to show up in the header. But I can't place it there, because is has to be in the blog(I think). Isn't there a way to place it outside the blog module? Unfortunately Post Image can't be located outside the Blog control. I've found a plug-in which creates a post featured image shortcode: https://wordpress.org/plugins/add-post-thumbnail-shortcode/ You can add WP widget area control in Themler and then use this shortcode in the text widget in WP. I've tested this plug-in on WP 3.8 on Themler's cloud. Looks like it works ok. Most probably this plug-in will work on WP 4.1.x too > Is there a way to place a video in the slider/head? You can insert youtube video by adding Video control (Insert >> other). If you want some other video you can add WP Widget Area control and then insert Text widget with appropriate video code into this Widget Area in WP. Please keep us posted about the progress. Thank you, Olivia
anneke
anneke posted this 31 March 2015
Unfortunately the add-post-thumbnail-shortcode doesn't work that well.
When I create a widget area and paste the shortcode in it, I'll get an error (the featured image also shows up).
'Warning: Illegal string offset 'size' in /home/sofea/public_html/preview2/wp-content/plugins/add-post-thumbnail-shortcode/post_thumbnail_shortcode.php on line 17'
The plug-in isn't downloaded very much either, so that's also a risk ofcourse.
Kind regards,
Hi, Unfortunately the add-post-thumbnail-shortcode doesn't work that well. When I create a widget area and paste the shortcode in it, I'll get an error (the featured image also shows up). *'Warning: Illegal string offset 'size' in /home/sofea/public_html/preview2/wp-content/plugins/add-post-thumbnail-shortcode/post_thumbnail_shortcode.php on line 17'* The plug-in isn't downloaded very much either, so that's also a risk ofcourse. Kind regards,
You can search for the different plug-in.
In any case Themler does not support such feature.
I don't know what else to suggest.
The future Themler update will support Custom templates feature. So you will be able to create separate template for each page in addition to built-in Post, Page, Blog, Home, etc. Maybe this feature will help you to achieve the desired result.
Please let us know if you have any other questions/issues.
You can search for the different plug-in. In any case Themler does not support such feature. I don't know what else to suggest. The future Themler update will support Custom templates feature. So you will be able to create separate template for each page in addition to built-in Post, Page, Blog, Home, etc. Maybe this feature will help you to achieve the desired result. Please let us know if you have any other questions/issues. Thank you, Olivia
