Impossible to update :
Please attach the problem theme. You can not update it, right?
Yes I can not update to v.228 (not v.322).
I can not attach the problem theme, because I can not run Themler anymore !
Hello, Yes I can not update to v.228 (not v.322). I can not attach the problem theme, because I can not run Themler anymore !Hi,
There should be the back up theme on your site that was created before update.
Thanks for the theme, I see the issue, I'll contact our developers about that and will let you know the results.
I had the same problem, they say it will be fixed in the next beta
I had the same problem, they say it will be fixed in the next betaHi,
Yes, thanks. The problem will be fixed in the next update. Please consider using the old version for now.
Are you talking about v.322beta or 328 ?
Sorry the tilte of my post is wrong...
I have the problem with v.328
The fix will be available in the next hot-fix update (following the 328 version).
