define fields shopping cart
Amilcar Botelho Rubim Junior
Amilcar Botelho Rubim Junior posted this 09 August 2016
Where do I define the fields the products that will appear in páginna purchase summary.
For example I want to take the field rate.
Att..
Amilcar
Where do I define the fields the products that will appear in páginna purchase summary. For example I want to take the field rate. Att.. Amilcar
19 Comments
Support Team posted this 10 August 2016
Hello Amilcar ,
the Shopping Cart fields are not set up in Themler. Shopping cart is set up under ViertueMart settings in Joomla admin back end. May be sometimes special plugins are needed. You'd better search on VM forums
Hello Amilcar , the Shopping Cart fields are not set up in Themler. Shopping cart is set up under ViertueMart settings in Joomla admin back end. May be sometimes special plugins are needed. You'd better search on VM forums regards, Aileen
Amilcar Botelho Rubim Junior posted this 10 August 2016
Ok I understand your answer.
Just not to get any questions.
The attached file is a part of Themler screen and indicate the fields that wish to modify.
My question is if I use a specific plugin will be no conflict with the layout of Themler, especially when there is an update of the layout?
att..
Amilcar
Ok I understand your answer. Just not to get any questions. The attached file is a part of Themler screen and indicate the fields that wish to modify. My question is if I use a specific plugin will be no conflict with the layout of Themler, especially when there is an update of the layout? att.. Amilcar
Support Team posted this 11 August 2016
I can not say for sure how it will work, but please feel free to try. I think that there should not be any issues about that.
Hi, I can not say for sure how it will work, but please feel free to try. I think that there should not be any issues about that. Sincerely, Hella
alexarafatonline
alexarafatonline posted this 30 July 2025
Hi Amilcar, I had a similar question before about customizing the purchase summary page. To remove a field like "rate," I had to tweak the display logic in the cart or checkout template—depends on the system you’re using. It’s kind of like discovering Plaza Singapore food options—at first glance it seems standard, but once you're there in Dhoby Ghaut, you realize there's so much variety tucked into every corner. Just takes a little digging!
Hi Amilcar, I had a similar question before about customizing the purchase summary page. To remove a field like "rate," I had to tweak the display logic in the cart or checkout template—depends on the system you’re using. It’s kind of like discovering [Plaza Singapore food][1] options—at first glance it seems standard, but once you're there in Dhoby Ghaut, you realize there's so much variety tucked into every corner. Just takes a little digging! [1]: https://singaporemalls.sg/plaza-singapore/
kristinajames308
kristinajames308 posted this 10 August 2025
try nullsbrawlls
try [url=https://nullsbrawlls.de/] nullsbrawlls [/url]
dajah60378
dajah60378 posted this 15 December 2025
When defining fields in a shopping cart, clear pricing and item details are essential for a smooth user experience. The wendys coffee menu helps illustrate this by showing how organized menu pricing allows customers to quickly understand costs before checkout. Having accurate price fields, just like a well-structured menu, builds trust and reduces confusion during the buying process.
When defining fields in a shopping cart, clear pricing and item details are essential for a smooth user experience. The [wendys coffee menu][1] helps illustrate this by showing how organized menu pricing allows customers to quickly understand costs before checkout. Having accurate price fields, just like a well-structured menu, builds trust and reduces confusion during the buying process. [1]: https://wendysmenuprice.com/wendys-coffee-menu/
joeroot.pk80
joeroot.pk80 posted this 15 December 2025
I actually have the same question and I’m trying to figure this out as well. I’m not sure where the fields for the purchase summary are defined, or how to control which product fields appear there. I’m also specifically interested in pulling in something like the rate field. If anyone can point to where this is configured or explain how to customize the purchase summary fields, I’d really appreciate it too. It kind of reminds me of building out a digital menu experience — like organizing items on the Texas Roadhouse menu — where only certain details (price, description, or category) are shown depending on context. Getting that level of control would make the whole setup much clearer and more user-friendly, similar to how this website lays out menu information cleanly and intuitively.
I actually have the same question and I’m trying to figure this out as well. I’m not sure where the fields for the purchase summary are defined, or how to control which product fields appear there. I’m also specifically interested in pulling in something like the rate field. If anyone can point to where this is configured or explain how to customize the purchase summary fields, I’d really appreciate it too. It kind of reminds me of building out a digital menu experience — like organizing items on the Texas Roadhouse menu — where only certain details (price, description, or category) are shown depending on context. Getting that level of control would make the whole setup much clearer and more user-friendly, similar to how [this website][1] lays out menu information cleanly and intuitively. [1]: https://thetexasroadhousemenu.com/
mejov57740
mejov57740 posted this 06 January 2026
A shopping cart is designed to gather selected items in one place so the purchasing process feels simple and orderly, and it creates a chance for customers to think about their choices before completing payment. This tool can help people stay aware of their budget and quantities while keeping everything clearly in front of them. With better organization, there is always a sense of possibility that shopping becomes faster and more relaxed. Two or three additional points show that carts also reduce confusion, support smooth movement through a store, and make it easier to compare options. When a store plans its target time opening around busy periods, the cart system offers an opportunity to handle crowds efficiently. Overall, the idea gives every buyer a feeling that a balanced and convenient experience is achievable.
A shopping cart is designed to gather selected items in one place so the purchasing process feels simple and orderly, and it creates a chance for customers to think about their choices before completing payment. This tool can help people stay aware of their budget and quantities while keeping everything clearly in front of them. With better organization, there is always a sense of possibility that shopping becomes faster and more relaxed. Two or three additional points show that carts also reduce confusion, support smooth movement through a store, and make it easier to compare options. When a store plans its [target time opening][1] around busy periods, the cart system offers an opportunity to handle crowds efficiently. Overall, the idea gives every buyer a feeling that a balanced and convenient experience is achievable. [1]: https://target-hours.org/
thomasday4567
thomasday4567 posted this 05 February 2026
In shopping cart terms, “fields” usually mean the data points that describe each item added before checkout. Common fields include product name, item ID, price, quantity, subtotal, taxes, and total amount, plus optional fields like notes or modifiers. For food ordering, clear fields matter even more because users want to see portion details, calorie info, and price changes instantly when customizing a meal. Menus with structured categories and transparent pricing make this process smoother and reduce checkout confusion. A good real-world example of how menu data maps cleanly into cart fields can be seen here: https://thepandaexpressmenu.com/
amitykailani
amitykailani posted this 05 February 2026
Defining and customizing shopping cart fields would be a great improvement. Store owners should be able to add, remove, or edit fields (like phone number, delivery notes, or custom options) directly from settings without needing extra plugins or code. This would make the checkout process more flexible, user-friendly, and better suited for different business needs. I also came across Kfcmenuu burger options south africa while browsing online, which was quite helpful.
Defining and customizing shopping cart fields would be a great improvement. Store owners should be able to add, remove, or edit fields (like phone number, delivery notes, or custom options) directly from settings without needing extra plugins or code. This would make the checkout process more flexible, user-friendly, and better suited for different business needs. I also came across [Kfcmenuu burger options south africa][1] while browsing online, which was quite helpful. [1]: https://kfcmenuu.co.za/
akramnazeer1122
akramnazeer1122 posted this 02 March 2026
With customizable toppings and dressings, sheetz salads make it easy to create a meal that fits your taste.
With customizable toppings and dressings, [sheetz salads][1] make it easy to create a meal that fits your taste. [1]: https://sheetz.us/sheetz-salad-menu/
aqeelyt196
aqeelyt196 posted this 11 March 2026
Online gaming forums often talk about the unlock ff beta apk 2026, where testers share their experiences with early updates and gameplay changes. fore free file visit website https://thebetaserver.com/
aqeelyt196
If you enjoy casual dining, checking yard house pricing can help you know the expected cost of appetizers, meals, and drinks at Yard House. for more info visit website https://yardrestaurantmenu.us/
aqeelyt196
If you enjoy sweet treats and coffee, checking the dunkin donuts menu can help you find the best options available at Dunkin' stores. for more offer visit website https://dunkinmenuwithprice.com/
lboy29175
lboy29175 posted this 11 March 2026
If you want to sell Louis Vuitton bag Dubai, you will find many luxury buyers interested in this iconic brand. Louis Vuitton bags are known for their durability and timeless design, making them highly desirable in the resale market. Professional buyers evaluate the bag’s condition, model, and authenticity before offering a fair resale price.
If you want to [sell Louis Vuitton bag Dubai][1], you will find many luxury buyers interested in this iconic brand. Louis Vuitton bags are known for their durability and timeless design, making them highly desirable in the resale market. Professional buyers evaluate the bag’s condition, model, and authenticity before offering a fair resale price. [1]: https://valuecreationuae.com/
cora9881
cora9881 posted this 12 March 2026
things to do in nashville include visiting the Grand Ole Opry, exploring the Country Music Hall of Fame and Museum, walking Broadway (Nashville), enjoying live music, tasting hot chicken, and relaxing downtown tonight.
[things to do in nashville][1] include visiting the Grand Ole Opry, exploring the Country Music Hall of Fame and Museum, walking Broadway (Nashville), enjoying live music, tasting hot chicken, and relaxing downtown tonight. [1]: https://thingstodoinnashvilletn.com
mannakhan5507576
mannakhan5507576 posted this 29 April 2026
Good question! Defining fields in a shopping cart is really important for capturing the right user information like product options, quantity, pricing, and customer details. It helps improve both functionality and user experience.
Also, when dealing with pricing and taxes in carts, tools like this VAT calculator can be helpful for accurate calculations: https://vatcalculatorrireland.com/
Hope this helps!
Good question! Defining fields in a shopping cart is really important for capturing the right user information like product options, quantity, pricing, and customer details. It helps improve both functionality and user experience. Also, when dealing with pricing and taxes in carts, tools like this VAT calculator can be helpful for accurate calculations: https://vatcalculatorrireland.com/ Hope this helps!
gorillafight684
gorillafight684 posted this 4 weeks ago
Discover affordable breakfast choices through the dairy queen breakfast menu with prices , including biscuits, burritos, pancakes, and coffee combinations.
Discover affordable breakfast choices through the [dairy queen breakfast menu with prices][1] , including biscuits, burritos, pancakes, and coffee combinations. [1]: https://thedairyqueenmenu.us/
calculadoraaaliciia
calculadoraaaliciia posted this 4 weeks ago
You can define the fields that appear in the purchase summary page within your checkout or summary configuration—usually where line items or product details are mapped. To include a field like rate, make sure it is part of the product data model and explicitly added to the summary display settings or template.
For a simple example of structured calculations, you can refer to alicia calculadora, which demonstrates clean handling of basic fields like values and rates in a user-friendly way.
You can define the fields that appear in the purchase summary page within your checkout or summary configuration—usually where line items or product details are mapped. To include a field like rate, make sure it is part of the product data model and explicitly added to the summary display settings or template. For a simple example of structured calculations, you can refer to [alicia calculadora][1], which demonstrates clean handling of basic fields like values and rates in a user-friendly way. [1]: https://calculadoraaliciia.es/
