Picture in article not showing
Virago
Virago posted this 11 August 2016
I use Joomla 3.6.2, Themler 3.2.8, Template based on Themler Default.
If I disable show category in some article options (menu item or article or global settings) then page not show article picture from article settings. Any solution?
I use Joomla 3.6.2, Themler 3.2.8, Template based on Themler Default. If I disable show category in some article options (menu item or article or global settings) then page not show article picture from article settings. Any solution?
Support Team posted this 12 August 2016
Do you mean Blog Template or Single Article view?
Themler theme uses Post and Page template for Single Article view. The difference is in metadata (category, date, etc). If metadata disabled Themler theme assigns Page template to Single Article. If metadata enabled Themler theme assigns Post template.
Please check Page template. Looks like Post Image control is not added to this template (under the Posts control parameters on the ribbon).
http://answers.themler.com/articles/36343/how-to-work-with-templates-in-joomla-themes
Hi, Do you mean Blog Template or Single Article view? Themler theme uses Post and Page template for Single Article view. The difference is in metadata (category, date, etc). If **metadata disabled** Themler theme assigns **Page template** to Single Article. If **metadata enabled** Themler theme assigns **Post template**. Please check Page template. Looks like Post Image control is not added to this template (under the Posts control parameters on the ribbon). http://answers.themler.com/articles/36343/how-to-work-with-templates-in-joomla-themes Thank you, Olivia
