Are the themes responsive? Or at least set up to be able to be responsive through Artisteer?
Are the themes responsive? Or at least set up to be able to be responsive through Artisteer?Last edited 20 August 2014 by Support Team
it is essential to use a manual as it is not easy to use especially in the run modules already installed
it is essential to use a manual as it is not easy to use especially in the run modules already installedHi,
Thanks for contacting us!
The themes are responsive, they are based on the Bootstrap grid system.
Also the manual is coming soon, please wait a bit.
For now you can ask any questions here and our support stuff and other users will be glad to help you.
Is having a responsive theme dependent on the version of Artisteer I have or just on which theme I choose?
I am currently at version 3.1.0.46558
Bob
Is having a responsive theme dependent on the version of Artisteer I have or just on which theme I choose? I am currently at version 3.1.0.46558 BobHello Bob,
Artisteer themes provide responsive web design feature starting from version 4.0 - so please make sure to choose accordingly.
Best regards,
Tammy
