Videos on a container with contact form are not getting render
nextmedia4u
nextmedia4u posted this 13 August 2016
1 Hi, I built a container that hold a youtube video and below it a contact form. from some reason the video won't render well on mobile devices. What can be the problem?
2 What is the proper way to add video and contact form on the same container?
3 What is the proper way to edit a video in a widget so in every page i can post another video?
1 Hi, I built a container that hold a youtube video and below it a contact form. from some reason the video won't render well on mobile devices. What can be the problem? 2 What is the proper way to add video and contact form on the same container? 3 What is the proper way to edit a video in a widget so in every page i can post another video?
nextmedia4u
http://www.keshet-fin.co.il/%D7%9E%D7%A8%D7%9B%D7%96-%D7%94%D7%A4%D7%A8%D7%99%D7%A9%D7%94/
Support Team posted this 15 August 2016
unfortunately there's no video at http://www.keshet-fin.co.il/%D7%9E%D7%A8%D7%9B%D7%96-%D7%94%D7%A4%D7%A8%D7%99%D7%A9%D7%94/
But I'd recommend that you add Video control and to make it responsible enable the responsive option like on screenshot
I see that Contact form is added as Widget. If you add Video as Widget from WP admin back end it'd be located in the same container as Contact form.
But in this case you probably need to apply some custom CSS or adjust widget options to make the video responsible.
The widget allows to be displayed on selected pages only. So you may add several video Widgets with different video sources. So different videos are displayed on different pages.
Hello, unfortunately there's no video at http://www.keshet-fin.co.il/%D7%9E%D7%A8%D7%9B%D7%96-%D7%94%D7%A4%D7%A8%D7%99%D7%A9%D7%94/ But I'd recommend that you add Video control and to make it responsible enable the responsive option like on screenshot !Video.png! I see that Contact form is added as Widget. If you add Video as Widget from WP admin back end it'd be located in the same container as Contact form. But in this case you probably need to apply some custom CSS or adjust widget options to make the video responsible. The widget allows to be displayed on selected pages only. So you may add several video Widgets with different video sources. So different videos are displayed on different pages. regards, Aileen
