Is There A Suggested SEO Plugin For WordPress That Works With Themler Codes?
David Marchione
David Marchione posted this 15 August 2016
I notices Yoast is having difficulty understanding the content when edited using Themler. For instance, a simple h2 is replaced with [text tag="h2"] causing Yoast not to see subheaders. This causes Yoast to give bad advice.
When I Inspect An Element from the browser view I believe I'm seeing proper on-page SEO elements.
Any suggestion for an SEO plugin that doesn't choke when working with Themler? Any suggestions?
I notices Yoast is having difficulty understanding the content when edited using Themler. For instance, a simple h2 is replaced with [text tag="h2"] causing Yoast not to see subheaders. This causes Yoast to give bad advice. When I Inspect An Element from the browser view I believe I'm seeing proper on-page SEO elements. Any suggestion for an SEO plugin that doesn't choke when working with Themler? Any suggestions?
Support Team posted this 16 August 2016
We haven't tested the SEO plug-ins with our themes. I hope that somebody will suggest something to you.
Hi, We haven't tested the SEO plug-ins with our themes. I hope that somebody will suggest something to you. Sincerely, Hella
zzGreg
zzGreg posted this 17 August 2016
I am having similar issues with Yoast seeing content that is inside my Themler template (my template is my site). I too would like to know if there better choice for a SEO plugin.
