Dear Sirs,
I am still asking support for this magento template: http://test.kokomamas.it
I am going crazy with themler for magento: always getting problems. I have to complete the theme for client and I cannot becouse themler doesn't work!
There are still several support questions open and this is ruining my job.
1) Today I was working on home template and suddenly I didn't see anymore one of my CMS static block in home page. the block was already inserted since a few days and correctly functioning. now it disappers from the body of the homepage (see attachement)
It is still present on the left, inside the outline column, I also tried to delete the "cms code" and insert it again but it seems impossible to delete.
2) An old problem that you fixed here: http://answers.themler.com/questions/93052/loosing-format-after-update
is appearing again, that is the footer layout is no more wide in home page, while it is in other templates.
3) Still waiting for this problem: http://answers.themler.com/questions/90403/magento-product-details-template that is not yet solved by your developers, is it?
4) I am obliged to come back to the question of languages in magento, becouse I do not know a solution to customize text and links for different languages. for exemple, in the attached image you see 3 columns, each with an image and a button and one colomun also has text "Spedizioni gratuite per ordini superiori a € 59,00". how can I manage link to different language pages? how can I get translated text in the right language?
Marco Dear Sirs, I am still asking support for this magento template: http://test.kokomamas.it I am going crazy with themler for magento: always getting problems. I have to complete the theme for client and I cannot becouse themler doesn't work! There are still several support questions open and this is ruining my job. 1) Today I was working on home template and suddenly I didn't see anymore one of my CMS static block in home page. the block was already inserted since a few days and correctly functioning. now it disappers from the body of the homepage (see attachement)!missing-cms-block.jpg! It is still present on the left, inside the outline column, I also tried to delete the "cms code" and insert it again but it seems impossible to delete. 2) An old problem that you fixed here: http://answers.themler.com/questions/93052/loosing-format-after-update is appearing again, that is the footer layout is no more wide in home page, while it is in other templates. 3) Still waiting for this problem: http://answers.themler.com/questions/90403/magento-product-details-template that is not yet solved by your developers, is it? 4) I am obliged to come back to the question of languages in magento, becouse I do not know a solution to customize text and links for different languages. for exemple, in the attached image you see 3 columns, each with an image and a button and one colomun also has text "Spedizioni gratuite per ordini superiori a € 59,00". how can I manage link to different language pages? how can I get translated text in the right language? !different-text-and-links-for-languages.jpg! Regards Marco
