style problems with checkout button in magento
marco.marino1971
marco.marino1971 posted this 19 August 2016
Greetings,
I have a problem with some button styles in magento theme on http//:test.kokmamas.it
I want the style of a productbuy button to be applied also to a checkout button, so I copied and pasted the style in themler
It's ok, but the text color of link: it seems that even if the checkout button gets the style I applied, is also getting the color of content block link text, that is brown and not white.
Please have a look to the attachement
Can you help me?
Marco
Greetings, I have a problem with some button styles in magento theme on http//:test.kokmamas.it I want the style of a productbuy button to be applied also to a checkout button, so I copied and pasted the style in themler It's ok, but the text color of link: it seems that even if the checkout button gets the style I applied, is also getting the color of content block link text, that is brown and not white. Please have a look to the attachement !link-button-styles.jpg! Can you help me? Regards Marco
Support Team posted this 19 August 2016
I cannot reproduce the issue with the default theme: the style is copied correctly including the font color. Please make sure you are comparing the style for the same state: default-default or hover-hover etc.
Hello, I cannot reproduce the issue with the default theme: the style is copied correctly including the font color. Please make sure you are comparing the style for the same state: default-default or hover-hover etc. Sincerely, Nettie, BillionDigital Team
