Joomla 3.6.2 Themler 334 cannot install Template
Bayern
Bayern posted this 20 August 2016
ERROR:
Fehler
Unable to write entry
Es kann kein Installationspaket gefunden werden!
What's to do?
ERROR: Fehler Unable to write entry Es kann kein Installationspaket gefunden werden! What's to do?
16 Comments
acannavacciuolo
acannavacciuolo posted this 20 August 2016
I can not install Themler of Joomla 3.6.2.
This is the error:
Error
Unable to create destination
Hi, I can not install Themler of Joomla 3.6.2. This is the error: Error Unable to create destination
dpodesta
dpodesta posted this 21 August 2016
I also can't install templates.
unable to write entry
unable to find package inastaller.
I also can't install templates. unable to write entry unable to find package inastaller.
Support Team posted this 22 August 2016
Hello guys,
I have got no problems installing Themler theme to Joomla 3.6.2 version. I'm working with the latest Themler theme version 334 .
So please submit new separate private topic where provide:
1.access to your Joomla admin back end;
2.FTP access to Joomla folder
Hello guys, I have got no problems installing Themler theme to Joomla 3.6.2 version. I'm working with the latest Themler theme version 334 . So please submit new separate private topic where provide: 1.access to your Joomla admin back end; 2.FTP access to Joomla folder regards, Aileen
fredal1
fredal1 posted this 24 August 2016
Idem problem
Joomla 3.6.2
Themler 337
Import in joomla
Erreur
Impossible de trouver un pack d'installation
solution ?
Thx
Hi Idem problem Joomla 3.6.2 Themler 337 ------------------------ Import in joomla ------------------------ Erreur Unable to write entry Impossible de trouver un pack d'installation _________________________________________________ solution ? Thx
fredal1
i have problem
Themler 337
Import in joomla 3.6.2
Erreur joomla
solution ?
Thx
Hi i have problem Themler 337 Import in joomla 3.6.2 Erreur joomla Unable to write entry Impossible de trouver un pack d'installation solution ? Thx
Sem
Sem posted this 24 August 2016
Today I updated themler version than created new themler exported it and tried to install on new joomla 3.6.2 website and wasn't able to do that as it had problems with jinstall. I tried older themler templates and they installed properly. so please fix that important bug. Thanks
Hello Today I updated themler version than created new themler exported it and tried to install on new joomla 3.6.2 website and wasn't able to do that as it had problems with jinstall. I tried older themler templates and they installed properly. so please fix that important bug. Thanks
fredal1
I confirm I tried with an old template themler and it works, 337 does not work with me
> Hello > Today I updated themler version than created new themler exported it and tried to install on new joomla 3.6.2 website and wasn't able to do that as it had problems with jinstall. I tried older themler templates and they installed properly. so please fix that important bug. Thanks I confirm I tried with an old template themler and it works, 337 does not work with me
Bayern
Bayern posted this 24 August 2016
Here's a temporary workaround
If this theme cannot be installed in joomla then unpack it and pack again
then it should be installed
Here's a temporary workaround If this theme cannot be installed in joomla then unpack it and pack again then it should be installed
fredal1
thank you very much :-)
> Here's a temporary workaround > > If this theme cannot be installed in joomla then unpack it and pack again > > then it should be installed thank you very much :-)
martindezwaan
martindezwaan posted this 24 August 2016
When i unpack the zip file with "7zip" i get an error message (There is data at the end of the payload data) maybe there is a problem in the zip file???
fredal1
I use winrar .zip sorry !
> When i unpack the zip file with "7zip" i get an error message (There is data at the end of the payload data) maybe there is a problem in the zip file??? I use winrar .zip sorry !
Bayern
Bayern posted this 25 August 2016
i use also WinRAR
i use also WinRAR
martindezwaan
martindezwaan posted this 25 August 2016
The problem is not that you use winrar.zip! But that the template cannot be installed in joomla. Your workaround is ok!.
When i unpack the template zip file i get this payload data error message: conclusion there is something wrong with the template zip file from Themler export function.
> > When i unpack the zip file with "7zip" i get an error message (There is data at the end of the payload data) maybe there is a problem in the zip file??? > > I use winrar .zip sorry ! The problem is not that you use winrar.zip! But that the template cannot be installed in joomla. Your workaround is ok!. When i unpack the template zip file i get this payload data error message: conclusion there is something wrong with the template zip file from Themler export function.
Support Team posted this 26 August 2016
please either use a backup of the theme or unzip and pack the theme again. This should help.
For details please refer to http://answers.themler.com/questions/96160/themler-v-340-hot-fix-update-26-august-2016
Hello, please either use a backup of the theme or unzip and pack the theme again. This should help. For details please refer to http://answers.themler.com/questions/96160/themler-v-340-hot-fix-update-26-august-2016 regards, Aileen
dpodesta
dpodesta posted this 27 August 2016
Error
Unable to find install package
I get this error when trying to install themes created on themler desktop. If I export from the themler website they install.
Error Unable to write entry Unable to find install package I get this error when trying to install themes created on themler desktop. If I export from the themler website they install.
Support Team posted this 29 August 2016
Hello David,
this is the issue on our end.
Please follow the suggestion from the article http://answers.themler.com/questions/96160/themler-v-340-hot-fix-update-26-august-2016
Hello David, this is the issue on our end. Please follow the suggestion from the article http://answers.themler.com/questions/96160/themler-v-340-hot-fix-update-26-august-2016 Regards, Aileen
