Is it possible with Themler and WordPress?
bandibacsi2
bandibacsi2 posted this 22 August 2016
Today I saw a cool website vestrainet.com I have two questions about it.
  • Is it possible to change the colour of the top menu bar if the front
    page if it is scrolled down? First it is white then black and white
    again.
  • On frontage if you scroll down the background video shrinks into a
    screen. Does anybody know a WP plugin that does similar scrolling
    screen effect?
Andras
Hello, Today I saw a cool website [vestrainet.com][1] I have two questions about it. - Is it possible to change the colour of the top menu bar if the front page if it is scrolled down? First it is white then black and white again. - On frontage if you scroll down the background video shrinks into a screen. Does anybody know a WP plugin that does similar scrolling screen effect? Thanks, Andras [1]: http://www.vestrainet.com/
Support Team posted this 23 August 2016
  1. In general yes. Themler uses bootstrap affix for "Fix on Scroll" extension. You can add background and transition to Affix container under the Extensions. Bit this will work only in case when the Contained with "Fix on Scroll" extension does not have own background. otherwise the background of the container will overlap the background of the Affix container.
  2. Unfortunately I don't know such plugins.
Hi, 1. In general yes. Themler uses bootstrap affix for "Fix on Scroll" extension. You can add background and transition to Affix container under the Extensions. Bit this will work only in case when the Contained with "Fix on Scroll" extension does not have own background. otherwise the background of the container will overlap the background of the Affix container. !container-affix.png! 2. Unfortunately I don't know such plugins. Thank you, Olivia
