The next Themler update will support syntax highlight in the css/html editors and full screen pop-up editor with numbered lines:
Theme Settings >> Additional CSS:
Pop-up editor:
Olivia, ask your developers would it take much of their time to ditch (or leave as it is) these options and make a button "Open in editor". All file extensions for web are already registered in windows for some of the our own code editors. And if Themler can open this part in our code editor to work on it, then on Save in code editor Themler imports code in those fields.
I dont excpect it it easy to do, but just would like answer from them, how they see on it.
Asking mainly because of one reason. Our code editors have option to warn us if code is wrong and not after coding standards. Some character misssing, some is to much, code wont parse, etc...
Second reason is Undo button in code editors. Using Ctrl + Z inside those fields is not very secure and usefull.
Olivia, ask your developers would it take much of their time to ditch (or leave as it is) these options and make a button "Open in editor". All file extensions for web are already registered in windows for some of the our own code editors. And if Themler can open this part in our code editor to work on it, then on Save in code editor Themler imports code in those fields. I dont excpect it it easy to do, but just would like answer from them, how they see on it. Asking mainly because of one reason. Our code editors have option to warn us if code is wrong and not after coding standards. Some character misssing, some is to much, code wont parse, etc... Second reason is Undo button in code editors. Using Ctrl + Z inside those fields is not very secure and usefull.
