social icon link
idcreate
idcreate posted this 23 August 2016
Hi, when I insert an actuall social link - the button goes to a share option.. this is not what I want. I set the static URL - as this is what I want - but it still does the share option. Please fix.
Support Team posted this 24 August 2016
Hello Craig,
Currently the Social Icons control does not allow to specify URL without sharing. If you want to specify static URL without sharing functionality consider using the Image control instead
Hello Craig, Currently the Social Icons control does not allow to specify URL without sharing. If you want to specify static URL without sharing functionality consider using the Image control instead Regards, Aileen
christopher
christopher posted this 20 November 2016
In Wordpress you can work around this bug by going to Editor (Appearance > Editor), clicking on and opening all the .php files listed down the right side, and searching for the social keyword (like "twitter" or "facebook"). You will find the href link for the social icon. Just cut and paste the correct URL between the two quote marks and click Update.
Note: The Social URLs are not centrally located in one .php file. Best to open and search them all for the offending social links. In my case, it was about twenty different .php files.
In Wordpress you can work around this bug by going to Editor (Appearance > Editor), clicking on and opening all the .php files listed down the right side, and searching for the social keyword (like "twitter" or "facebook"). You will find the href link for the social icon. Just cut and paste the correct URL between the two quote marks and click Update. Note: The Social URLs are not centrally located in one .php file. Best to open and search them all for the offending social links. In my case, it was about twenty different .php files.
