Themler v.337 Update (23-August-2016)
Support Team posted this 23 August 2016
Hi everyone,
We've updated Themler from the current Beta version.
The new version is 337.
Here is a list of fixes and features included in this Themler update:
Controls
MegaMenu
MegaMenu is a new type of the existing Horizontal menu control. This type allows to display menu subitems in columns. It needs 3 levels of menu items.
Supported for Joomla, WP, Magento, PrestaShop and HTML.
In the future updates MegaMenu will be available for Drupal. We also plan to support inserting CMS modules/widgets/banners inside megamenu items.
enter image description here
This is beta version of MegaMenu. Therefore unexpected issues are possible.
Please let us know if there are any issues or suggestions.
UI
  • Improved Home tab. All theme settings have been moved to the Home tab.
  • Added Suggest options to the Home tab (see above). The suggestions are based on the library of Sections.
    Suggest Homepage - this feature uses Pages (a bunch of Content Section + Header and Footer Sections.).
    Suggest Blog - this feature uses Blog Sections. This option can be used for Blog Template only. If you're using it on any other template Themler will switch the current template to Blog.
  • All control related settings have been moved to the Edit tab.
  • Improved hover and selection of controls in preview area. Now hover and selection frames match each other.
    • Hover & Selection before:
    • Hover & Selection now:
Fixes
General
  • Fixed layout issues that appeared in the previous update.
  • Fixed a few issues with "Expand to Bottom" extension.
Drupal
  • Improved working with Custom templates. Now if you have created a template for custom content type and added a node of the appropriate type the Custom template will display this node in Themler. Previously, Custom templates have always shown the content of the Front Page.
Joomla
  • Fixed issue with print icon in Joomla 3.6
  • A few minor fixes
Wordpress
  • A few minor fixes
Themler Team
Hi everyone, We've updated Themler from the current Beta version. The new version is 337. Here is a list of fixes and features included in this Themler update: [post:94911] Thank you, Themler Team
22 Comments
apsite
apsite posted this 23 August 2016
After updating I can't install it on my web. There is an error "Unable to write entry" .
Bayern
Bayern posted this 23 August 2016
still not installable in Joomla
apsite,
Please create a new Private topic and provide the access to the CMS admin panel.
Bayern,
We've assigned a task to our developers to check this issue.
looks like you have specific server configuration because I failed to reproduce this issue with new joomla 3.6.2 installation, updated joomla to 3.6.2 version on PHP 5.x and on PHP 7.0.4 and 7.0.10.
Could you please try installing theme by FTP and check joomla/tmp folder permissions.
apsite, Please create a new Private topic and provide the access to the CMS admin panel. Bayern, We've assigned a task to our developers to check this issue. looks like you have specific server configuration because I failed to reproduce this issue with new joomla 3.6.2 installation, updated joomla to 3.6.2 version on PHP 5.x and on PHP 7.0.4 and 7.0.10. Could you please try installing theme by FTP and check joomla/tmp folder permissions. Thank you, Olivia
pete17
pete17 posted this 23 August 2016
I too cant export as ZIP and then import into Joomla on the update. Im getting the "ERROR, Unable to write entry, unable to find install package" when uploading the theme. Im running joomla 3.6.2, Apache 2.4.23 and PHP 5.5.38 and nothing has changed apart from Themler updating earlier today. I had a deadline of tomorrow to complete the template and showing the client in the morning which has caused me a little issue :)
Iv tried uploading to tmp and installing from the folder on the server and get "Warning, JInstalller: Install: Cant find XML setup file. Error, Path does not have a valid package, Unable to find install package"
I too cant export as ZIP and then import into Joomla on the update. Im getting the "ERROR, Unable to write entry, unable to find install package" when uploading the theme. Im running joomla 3.6.2, Apache 2.4.23 and PHP 5.5.38 and nothing has changed apart from Themler updating earlier today. I had a deadline of tomorrow to complete the template and showing the client in the morning which has caused me a little issue :) Iv tried uploading to tmp and installing from the folder on the server and get "Warning, JInstalller: Install: Cant find XML setup file. Error, Path does not have a valid package, Unable to find install package"
jimmy.andersson
jimmy.andersson posted this 23 August 2016
Why haven't there been ANY UPDATE NOTICE to any of the subscribers on there E-Mail on how to update or how to use Themler to use the updates???? No notice AT ALL.. Alot of ppl think that themler and artisteer is DEAD!
We have used alot of Money on your products.. and no notice at all.. Not everyone read forums.. (Just search for it and found this) since we have "our real Work"..
So please for your own sake and ours.. send an mail to all your costumers about the updates.. how to update.. changes.. futures.. And the much more you offers.
thx :)
* I've lost a about 2 year becouse of this.. and many others have lost the same *
Why haven't there been ANY UPDATE NOTICE to any of the subscribers on there E-Mail on how to update or how to use Themler to use the updates???? No notice AT ALL.. Alot of ppl think that themler and artisteer is DEAD! We have used alot of Money on your products.. and no notice at all.. Not everyone read forums.. (Just search for it and found this) since we have "our real Work".. So please for your own sake and ours.. send an mail to all your costumers about the updates.. how to update.. changes.. futures.. And the much more you offers. thx :) *** I've lost a about 2 year becouse of this.. and many others have lost the same ***
Bayern
Bayern posted this 24 August 2016
Bayern,
Hi Olivia,
this post was only an information
it exists a private Topic already and i send a template.zip
the support wasn't also capable to install the template.
This error was for the first time with Version 331 - until 328 all works properly
and my Server Configuratin is OK ;-)
Best Regards Jürgen
> Bayern, > > We've assigned a task to our developers to check this issue. > looks like you have specific server configuration because I failed to reproduce this issue with new joomla 3.6.2 installation, updated joomla to 3.6.2 version on PHP 5.x and on PHP 7.0.4 and 7.0.10. > > Could you please try installing theme by FTP and check joomla/tmp folder permissions. > > Thank you, > Olivia > Hi Olivia, this post was only an information it exists a private Topic already and i send a template.zip the support wasn't also capable to install the template. This error was for the first time with Version 331 - until 328 all works properly and my Server Configuratin is OK ;-) Best Regards Jürgen
pdg.design
pdg.design posted this 24 August 2016
I can't import into Joomla after last update. I see the "ERROR, Unable to write entry, unable to find install package" when uploading the theme. I use joomla 3.6.2
francis
francis posted this 24 August 2016
Same here, Cant import template.
Error
Same here, Cant import template. Error Unable to write entry Unable to find install package
SOHOSYNERGY
SOHOSYNERGY posted this 24 August 2016
I've been following your updates since you first offered this product. I originally started with Artisteer and was initially reluctant to purchase Themler. That has changed. You have listened to your clients, and now even have added the Suggestion icon for headers footers homepage layout and even colors! When I started with Artisteer the Suggestions button save me hours of head banging trying to get a simple look and feel and really helped the creativity to flow. It also reduced time to delivery for my clients. These seemingly simple features are what now convinced me to purchase Themler E-commerce and renew my subscription this fall! Keep listening to the clients requests and implementing the feature requests and you will continually have me and others as loyal clients.
soulless
soulless posted this 24 August 2016
For Error
Unzip customtheme.zip
Open unziped folder and zip all files... then install theme with new zip file.
Themler path for ziping theme files is no good.
For Error Unable to write entry Unable to find install package Unzip customtheme.zip Open unziped folder and zip all files... then install theme with new zip file. Themler path for ziping theme files is no good.
elonri
elonri posted this 24 August 2016
I can no longer add a blank section - be it canvas or container. My mouse spins and nothing gets added. I've cleared my browser cache. Still nothing.
andrew34
andrew34 posted this 24 August 2016
When I drag and drop an image into a column which already has an HTML control, the whole page goes blank.
dn1353
dn1353 posted this 25 August 2016
After updating the horizontal menu can not be managed in DRUPAL !
Before upgrading My Horizontal menu could be managed in its place !.
Please help
Hi, After updating the horizontal menu can not be managed in DRUPAL ! Before upgrading My Horizontal menu could be managed in its place !. Please help
dn1353
I use DRUPAL
After upgrading to version 3.3.7 of the Horizontal menu editor lost the ability to control levels.
Please fix it
Hi I use DRUPAL After upgrading to version 3.3.7 of the Horizontal menu editor lost the ability to control levels. Please fix it
Hi everyone!
Thank you for your feedback!
For Error
If you receive this error while installing Themler theme in joomla 3.6.2 please try unzip the theme archive and zip it again. This may help.
Our developers are working on this issue.
elonri,
I've failed to reproduce this issue. Please create a new Private topic and attach the problem theme.
andrew34,
dn1353,
Looks like something overlaps the menu.
Could you please reset the Horizontal menu positioning and position menu again:
This may help. If the issue continues please create a new private topic and attach the problem theme.
Hi everyone! **Thank you for your feedback!** > For Error Unable to write entry Unable to find install package If you receive this error while installing Themler theme in joomla 3.6.2 please try unzip the theme archive and zip it again. This may help. Our developers are working on this issue. **elonri**, I've failed to reproduce this issue. Please create a new Private topic and attach the problem theme. **andrew34**, I've failed to reproduce this issue. Please create a new Private topic and attach the problem theme. **dn1353**, Looks like something overlaps the menu. Could you please reset the Horizontal menu positioning and position menu again: !reset-position.png! This may help. If the issue continues please create a new private topic and attach the problem theme. Thank you, Olivia
LGWeb
LGWeb posted this 25 August 2016
After the update I can't edit anything. It doesn't allow me to select anything.
LGWeb,
Please create a new Private topic and provide the access to the CMS admin panel so we can reproduce the issue.
LGWeb, Please create a new Private topic and provide the access to the CMS admin panel so we can reproduce the issue. Thank you, Olivia
LGWeb
LGWeb,
Just did. Thanks
> LGWeb, > > Please create a new Private topic and provide the access to the CMS admin panel so we can reproduce the issue. > > Thank you, > Olivia Just did. Thanks
dewald
dewald posted this 25 August 2016
I can't add a section to Article: Home... Is this right? It is automatically added to the Header.
Support Team posted this 26 August 2016
dewald,
We've fixed this issue in today's update.
dewald, We've fixed this issue in today's update. Thank you, Olivia
