Add new page with different content
marklaridon56
marklaridon56 posted this 23 August 2016
Hi I've seen a lot of questions on this. Has this now been resolved? Can you now add a new page on a HTML theme with different content to the other pages?
I can't work out how to do this
Hi I've seen a lot of questions on this. Has this now been resolved? Can you now add a new page on a HTML theme with different content to the other pages? I can't work out how to do this
17 Comments
Simply add the content inside green content area:
Everything outside this area will be a part of the template.
Hi, Simply add the content inside green content area: !insert-content-3.png! Everything outside this area will be a part of the template. Thank you, Olivia
marklaridon56
marklaridon56 posted this 25 August 2016
Hi Olivia
I've tried that. It's fine on the home page (capture1
But it doesn't work on a sub page, whether you selects the + blue or +green button, it always adds the new section to the template
Hi Olivia I've tried that. It's fine on the home page (capture1!Capture1.PNG! But it doesn't work on a sub page, whether you selects the + blue or +green button, it always adds the new section to the template!Capture2.PNG!
Support Team posted this 26 August 2016
Please move the Section from blue area to green area. Blue area is a template level. green area is a content level.
The issue with inserting Section to template level by green PLUS we've fixed in today's beta update.
Hi, Please move the Section from blue area to green area. Blue area is a template level. green area is a content level. The issue with inserting Section to template level by green PLUS we've fixed in today's [beta](page:53794) update. Thank you, Olivia
marklaridon56
marklaridon56 posted this 27 August 2016
Hi Olivia,
I, have applied the update, I have tried moving the section to the green area, I have tried adding a section to the green area, neither works. I have had themeler for a year now and because of this problem I have yet to be able to build a singe website with your system. Very disappointing!
Hi Olivia, I, have applied the update, I have tried moving the section to the green area, I have tried adding a section to the green area, neither works. I have had themeler for a year now and because of this problem I have yet to be able to build a singe website with your system. Very disappointing!
Support Team posted this 30 August 2016
please attach here your theme saved with option 'Include Themler..' and let us know what section and on what page you'd like to move inside the green area.
Hello, please attach here your theme saved with option 'Include Themler..' and let us know what section and on what page you'd like to move inside the green area. regards, Aileen
marklaridon56
marklaridon56 posted this 06 September 2016
Hi Allen,
I've attached the template
I'd like to be able to add any section to the green area, when you select a page (not a home page) all you can do is have lots of the same pages because you can only add a section to the blue template area.
I've been down this route with you before, sent you my theme, then after over a month you wrote back to me to say it was fixed, but it still isn't after nearly a year of trying
What I would like is a free extension to my licences for another year please and hopefully at some time in the future you can fix this
Mark
Hi Allen, I've attached the template I'd like to be able to add any section to the green area, when you select a page (not a home page) all you can do is have lots of the same pages because you can only add a section to the blue template area. I've been down this route with you before, sent you my theme, then after over a month you wrote back to me to say it was fixed, but it still isn't after nearly a year of trying What I would like is a free extension to my licences for another year please and hopefully at some time in the future you can fix this Regards Mark
Support Team posted this 07 September 2016
I have no problems with moving some content on Herb1 page into green section. I've just dragged the section and dropped it
and here is the result
Then I created test subpage and added section to its Content and Sidebars (freen area)
I'm attaching this modified theme
Hello, I have no problems with moving some content on Herb1 page into green section. I've just dragged the section and dropped it !Img1.png! and here is the result !Img2.png! Then I created test subpage and added section to its Content and Sidebars (freen area) !Img3.png! I'm attaching this modified theme Regards, Aileen
marklaridon56
marklaridon56 posted this 12 September 2016
Hi Allen,
So I go to my page Herb1 and try to add a section by pressing the green + button and nothing happens. It just doesn't add the section to the page. I've also highlighted this point several times. I'm sure you can understand my frustration with this
Again to highlight the point, I paid for this a year ago and it still doesn't work as advertised.
Mark
Hi Allen, So I go to my page Herb1 and try to add a section by pressing the green + button and nothing happens. It just doesn't add the section to the page. I've also highlighted this point several times. I'm sure you can understand my frustration with this Again to highlight the point, I paid for this a year ago and it still doesn't work as advertised. Regards Mark
Support Team posted this 13 September 2016
Hello Mark,
please make sure that the theme version is 349. This is a known issue for HTML sites, but it does not exist in the latest Themler version.
I can add Sections from library to default HTML theme and HTML theme I attached in previous post using the green plus icon.
Hello Mark, please make sure that the theme version is 349. This is a known issue for HTML sites, but it does not exist in the latest Themler version. I can add Sections from library to default HTML theme and HTML theme I attached in previous post using the green plus icon. Regards, Aileen
marklaridon56
marklaridon56 posted this 23 September 2016
Hi Aileen
How do I make sure the theme is 349, what do I do if it isn't?
Also I asked before, I bought the licences from you a year ago and because of the issues with the software I haven't been able to properly use the software, will you extend my licence for another year?
Mark
Hi Aileen How do I make sure the theme is 349, what do I do if it isn't? Also I asked before, I bought the licences from you a year ago and because of the issues with the software I haven't been able to properly use the software, will you extend my licence for another year? Regards Mark
Support Team posted this 28 September 2016
Hello Mark,
our logs indicate that current versions of your themes is 349 - the latest one.
As you still have problems with adding sections lets investigate this issue:
-export the theme with option 'Include Themler...' and attach here;
-are you experiencing the problem with adding sections in all themes?
Regarding the extending license. The logs indicate that you have been using Themler quite actively. All topics you posted are answered and the only one issue is now open - adding sections. In fact I do not see quite significant reasons why we should extend license for one year.
Hello Mark, our logs indicate that current versions of your themes is 349 - the latest one. As you still have problems with adding sections lets investigate this issue: -export the theme with option 'Include Themler...' and attach here; -are you experiencing the problem with adding sections in all themes? Regarding the extending license. The logs indicate that you have been using Themler quite actively. All topics you posted are answered and the only one issue is now open - adding sections. In fact I do not see quite significant reasons why we should extend license for one year. regards, Aileen
ijaz170000
ijaz170000 posted this 12 February 2025
Face Clinic offers expert skin care treatments to enhance your natural beauty, with personalized care for anti-aging, rejuvenation, and more. Read more to discover their wide range of services at Face Clinic. In Australia, medical certificates are crucial for validating health conditions for work, insurance, and other purposes. Check out here for more details on medical certificates in Australia.
Face Clinic offers expert skin care treatments to enhance your natural beauty, with personalized care for anti-aging, rejuvenation, and more. [Read more][1] to discover their wide range of services at Face Clinic. In Australia, medical certificates are crucial for validating health conditions for work, insurance, and other purposes. [Check out][2] here for more details on medical certificates in Australia. [1]: https://thefaceclinicpk.com [2]: https://medcertify.com.au/
ijaz170000
The website connects you with experienced hit-and-run lawyers for expert legal advice and consultations. If you're interested in housing jobs, check out here for listings and guidance on finding the right position.
The [website][1] connects you with experienced hit-and-run lawyers for expert legal advice and consultations. If you're interested in housing jobs, [check out][2] here for listings and guidance on finding the right position. [1]: http://lawyerhitandrun.com/ [2]: http://felonsfriendly.com/
ijaz170000
Apricocia is a clothing store offering stylish and trendy outfits for every occasion. Check out their collection.
Apricocia is a clothing store offering stylish and trendy outfits for every occasion. [Check out][1] their collection. [1]: https://apricocia.com/
ronniebuttler06
ronniebuttler06 posted this 22 April 2025
Face Clinic specializes in personalized skin care solutions for rejuvenation and aging concerns—explore more wellness-focused content at Health Chronicles.
Face Clinic specializes in personalized skin care solutions for rejuvenation and aging concerns—explore more wellness-focused content at [Health Chronicles][1]. [1]: https://health-chronicle.org/nutrition
happyriderreviews.com
happyriderreviews.com posted this 29 July 2025
Kinstra News is a comprehensive online news platform delivering the latest and most reliable updates from around the world. Our website covers a wide range of categories, including Asian news, football updates, general journal news, LFC (Liverpool Football Club) updates, Middle East news, Kuwait news, sports news, and global trends.
Our mission is to provide readers with accurate, timely, and engaging news, whether it's about sports, regional developments, or global affairs. Kinstra News combines in-depth analysis, credible reporting, and breaking news to ensure readers always stay informed.
https://kinstranews.com/
Kinstra News is a comprehensive online news platform delivering the latest and most reliable updates from around the world. Our website covers a wide range of categories, including Asian news, football updates, general journal news, LFC (Liverpool Football Club) updates, Middle East news, Kuwait news, sports news, and global trends. Our mission is to provide readers with accurate, timely, and engaging news, whether it's about sports, regional developments, or global affairs. Kinstra News combines in-depth analysis, credible reporting, and breaking news to ensure readers always stay informed. https://kinstranews.com/
dpcat24
dpcat24 posted this 29 July 2025
If you want to go faster in Speed Stars, you need to master the sweet spot between too slow and too fast. If you tap unevenly, your runner will lose balance. Keep your hands steady and sync your taps!
If you want to go faster in [Speed Stars][1], you need to master the sweet spot between too slow and too fast. If you tap unevenly, your runner will lose balance. Keep your hands steady and sync your taps! [1]: https://speedstarsfree.github.io
