Export Joomla Template from Mac
support123
support123 posted this 24 August 2016
When we export the Joomla Theme with content, it only creates a 2kb zip file.
Please advise, using Apple Mac, OSX EI Capitan
Hi When we export the Joomla Theme with content, it only creates a 2kb zip file. Please advise, using Apple Mac, OSX EI Capitan
Support Team posted this 24 August 2016
The issue should be fixed in the latest version. Please try to backup the themes and completely reinstall Themler the latest version for Mac, then update any theme to the latest version, click "Apply" or "Save", then F5, then save again. Let us know if the issue is still present.
Hello, The issue should be fixed in the latest version. Please try to backup the themes and completely reinstall Themler the latest version for Mac, then update any theme to the latest version, click "Apply" or "Save", then F5, then save again. Let us know if the issue is still present. Sincerely, Nettie, BillionDigital Team
joggie
joggie posted this 24 August 2016
Hi I have done that, I have also delete the /Users/xxxx/Libery/Themler folder, reloaded Themler, copied the data back done the update and reload, stil 2kb files exported.
I am sitting with a big issue I cant export to get the work out for the clients.
Hi I have done that, I have also delete the /Users/xxxx/Libery/Themler folder, reloaded Themler, copied the data back done the update and reload, stil 2kb files exported. I am sitting with a big issue I cant export to get the work out for the clients.
joggie
I have also tried on my other Apple Mac, it does the same. The version is 1.0.319 (fe25b)
Thanks for details. Does the issue happen with Joomla themes with content only? Or it also happens with Wordpress themes exported with content included?
Hello, Thanks for details. Does the issue happen with Joomla themes with content only? Or it also happens with Wordpress themes exported with content included? Sincerely, Nettie, BillionDigital Team
And also could you please specify the exact version of your system?
Sincerley,
Hello, And also could you please specify the exact version of your system? Sincerley, Nettie, BillionDigital Team
