Joomla upload error in v.337
bernhard5
bernhard5 posted this 24 August 2016
Fehler
Unable to write entry
Es kann kein Installationspaket gefunden werden!
Yesterday in v.322 everything ok, upload to joomla works. Today themler will be updates to v.337 and now i could not update my joomla. I tested and older zip from yesterday, the upload work. It is definitiv a problem in v.337. Joomla Version is 3.6.2.
What can i do? Is it possible to rollback to 322?
Fehler Unable to write entry Es kann kein Installationspaket gefunden werden! Yesterday in v.322 everything ok, upload to joomla works. Today themler will be updates to v.337 and now i could not update my joomla. I tested and older zip from yesterday, the upload work. It is definitiv a problem in v.337. Joomla Version is 3.6.2. What can i do? Is it possible to rollback to 322?
Our developers are working on this issue.
Themler creates a backup of the theme before update. You can use this backup or try rezipping the exported theme. It should help.
Hi, Our developers are working on this issue. Themler creates a backup of the theme before update. You can use this backup or try rezipping the exported theme. It should help. Thank you, Olivia
