is it possible to disable lightbox effect for images that are located in static pages in Wordpress?
I've ALREADY tried to disable it from the post content/post image in the default template and blog template but it has NO effect in both articles and static pages.
In static pages also there is no way to insert the class="no lightobx" tag since there is no way to edit the html sections in static pages.
Any hint?
(Suggestion: it would be great adding an "enable/disable" lightbox control in the Image general control)
Hi, is it possible to disable lightbox effect for images that are located in static pages in Wordpress? I've ALREADY tried to disable it from the post content/post image in the default template and blog template but it has NO effect in both articles and static pages. In static pages also there is no way to insert the class="no lightobx" tag since there is no way to edit the html sections in static pages. Any hint? (Suggestion: it would be great adding an "enable/disable" lightbox control in the Image general control)Last edited 26 August 2016 by antonio.erre
