Use Lightbox with iFrame Link
info2559
info2559 posted this 29 August 2016
Is there an option to open an iFrame with a lightbox?
I have tried different bootstrap modal scripts, but i couldn't get it work.
This is my html code:
<pre>
<a href="http://alpregio.outdooractive.com/ar-kaernten-ht/de/alpregio.jsp#q=heiligenblut&amp;tab=SearchTab" class="btn bootpopup" title="This is title" target="popupModal2">Open modal</a>
<div id="popupModal2" class="modal hide fade" tabindex="-1" role="dialog">
    <div class="modal-header">
        <button type="button" class="close" data-dismiss="modal">×</button>
            <h3>Title</h3>
    </div>
    <div class="modal-body">
      <iframe src="http://alpregio.outdooractive.com/ar-kaernten-ht/de/alpregio.jsp#q=heiligenblut&amp;tab=SearchTab" style="zoom:0.60" frameborder="0" height="250" width="99.6%"></iframe>
    </div>
    <div class="modal-footer">
        <button class="btn" data-dismiss="modal">OK</button>
    </div>
</div>
And my script:
    <script>
jQuery('.bootpopup').click(function(){
    var frametarget = $(this).attr('href');
  var targetmodal = $(this).attr('target');
  if (targetmodal == undefined) {
    targetmodal = '#popupModal';
  } else {
    targetmodal = '#'+targetmodal;
  if ($(this).attr('title') != undefined) {
    $(targetmodal+ ' .modal-header h3').html($(this).attr('title'));
    $(targetmodal+' .modal-header').show();
  } else {
     $(targetmodal+' .modal-header h3').html('');
    $(targetmodal+' .modal-header').hide();
    $(targetmodal).on('show', function () {
        $('iframe').attr("src", frametarget );
    $(targetmodal).modal({show:true});
  return false;
</script>
The bootstrap modal should work, isn't it? Why it doesn't?
Bettina
Is there an option to open an iFrame with a lightbox? I have tried different bootstrap modal scripts, but i couldn't get it work. This is my html code: <pre> <a href="http://alpregio.outdooractive.com/ar-kaernten-ht/de/alpregio.jsp#q=heiligenblut&amp;tab=SearchTab" class="btn bootpopup" title="This is title" target="popupModal2">Open modal</a> <div id="popupModal2" class="modal hide fade" tabindex="-1" role="dialog"> <div class="modal-header"> <button type="button" class="close" data-dismiss="modal">×</button> <h3>Title</h3> </div> <div class="modal-body"> <iframe src="http://alpregio.outdooractive.com/ar-kaernten-ht/de/alpregio.jsp#q=heiligenblut&amp;tab=SearchTab" style="zoom:0.60" frameborder="0" height="250" width="99.6%"></iframe> </div> <div class="modal-footer"> <button class="btn" data-dismiss="modal">OK</button> </div> </div> And my script: <script> jQuery('.bootpopup').click(function(){ var frametarget = $(this).attr('href'); var targetmodal = $(this).attr('target'); if (targetmodal == undefined) { targetmodal = '#popupModal'; } else { targetmodal = '#'+targetmodal; } if ($(this).attr('title') != undefined) { $(targetmodal+ ' .modal-header h3').html($(this).attr('title')); $(targetmodal+' .modal-header').show(); } else { $(targetmodal+' .modal-header h3').html(''); $(targetmodal+' .modal-header').hide(); } $(targetmodal).on('show', function () { $('iframe').attr("src", frametarget ); }); $(targetmodal).modal({show:true}); return false; }); </script> The bootstrap modal should work, isn't it? Why it doesn't? Regards, Bettina
Support Team posted this 30 August 2016
Hello Bettina,
have you tested this solution outside Themler or with one of default CMC themes? Does it work?
If yes, then the issue may be related to Themler. In this case please provide access to your CMS admin back end
Hello Bettina, have you tested this solution outside Themler or with one of default CMC themes? Does it work? If yes, then the issue may be related to Themler. In this case please provide access to your CMS admin back end Regards, Aileen
info2559
info2559 posted this 31 August 2016
Thanks, i have tested the code in jsfiddle. But it's ok now, i installed fancybox and did it with the plugin.
Your support is really great, thanks for your help!
Thanks, i have tested the code in jsfiddle. But it's ok now, i installed fancybox and did it with the plugin. Your support is really great, thanks for your help!
Support Team posted this 01 September 2016
Thanks, you are welcome. Please let us know if you need our further assistance.
Thanks, you are welcome. Please let us know if you need our further assistance. Sincerely, Hella
