Save slider to use in another template.
SRuff
SRuff posted this 30 August 2016
I made a slider in one template that I want to use in another. How do I save just the slider with all it's parameters and import it to a totally different template. I know how to copy/paste within a template and different pages. I.E. like how we are able to import sections from the library.
I made a slider in one template that I want to use in another. How do I save just the slider with all it's parameters and import it to a totally different template. I know how to copy/paste within a template and different pages. I.E. like how we are able to import sections from the library. Thank you
Support Team posted this 30 August 2016
The export/import option between themes is available for the sections only so you can insert the slider within the section and then export it for further use.
Hi, The export/import option between themes is available for the sections only so you can insert the slider within the section and then export it for further use. Sincerely, Hella
SRuff
Themler exports the whole template, not just the section. How do I save and export just one particular section and not the whole template?
Open the Section options in the top ribbon for the desired section. There will be the Export button and also Import.
Hi, Open the Section options in the top ribbon for the desired section. There will be the Export button and also Import. Sincerely, Hella
SRuff
Oh. It would help if I looked a little harder. :) Thanks for your help. Sorry to bother you.
