Themler Desktop Fails to Load
ptrader
ptrader posted this 30 August 2016
Not entirely sure this is a bug, but I am unable to load Themler desktop anymore. I'd been working in it all day and seemed to have caused an error where I was managing pages (Wordpress) and invoked the WP Themler editor. Realizing I wanted to be in the Desktop version, I closed the Chrome browser page were I had been managing the pages. When I tried to save my theme, I received errors that I already had Themler open elsewhere. The application then crashed and failed to start again despite several computer reboots.
I followed instructions to back up my themes and uninstalled/reinstalled the Windows desktop version of Themler. But it still does not start. I don't get any errors, just a spinning icon in my task bar. The status bar simply says "Waiting for 127.0.0.1..."
The log is apparently too long to paste here, so I've pasted the back half of the log with an error.
Dumps copied
Main finished
Adding firewall rules...
Firewall rules added
Replacing config files...
Config files replaced
Installing MySql...
MySql installed
Installing apache service...
Apache service installed
Installing CMS content...
CMS content installed
Creating link and icons...
Icons and links created...
Opening control panel...
Control panel opened
Creating shorcut...
Shortcut created
======== End of file C:\Users\Owner\AppData\Local\Temp\themler_install.log ========
======== Content of file C:\ProgramData\Themler\hd_data\themler_508354092\startup_logs\cms.log ========
Tue, 30 Aug 2016 20:37:01 +0000: openTheme(joomla)
Tue, 30 Aug 2016 20:37:01 +0000: install CMS
Tue, 30 Aug 2016 20:37:01 +0000: deployDB(joomla, joomla_, http://127.0.0.1:12080, /themler_508354092)
Tue, 30 Aug 2016 20:37:10 +0000: deployCMS(joomla)
Tue, 30 Aug 2016 20:38:37 +0000: configDbConnection(joomla, joomla_67800, configuration.php)
Tue, 30 Aug 2016 20:38:37 +0000: run CMS (joomla), error = 0, themeName = untitled
======== End of file C:\ProgramData\Themler\hd_data\themler_508354092\startup_logs\cms.log ========
ERROR:Unable to find file C:\Users\Owner\AppData\Roaming..\Local\Themler\ChromeData\chrome_debug.log
I'm not sure, but the last line seems wrong - you can have ...\AppData\Roaming OR \AppData\Local, but the correct path appears to be ...AppData\Local\Themler\ChromeData. And no, there's no chrome_debug.log there.
Please advise.
Pam Trader
Not entirely sure this is a bug, but I am unable to load Themler desktop anymore. I'd been working in it all day and seemed to have caused an error where I was managing pages (Wordpress) and invoked the WP Themler editor. Realizing I wanted to be in the Desktop version, I closed the Chrome browser page were I had been managing the pages. When I tried to save my theme, I received errors that I already had Themler open elsewhere. The application then crashed and failed to start again despite several computer reboots. I followed instructions to back up my themes and uninstalled/reinstalled the Windows desktop version of Themler. But it still does not start. I don't get any errors, just a spinning icon in my task bar. The status bar simply says "Waiting for 127.0.0.1..." The log is apparently too long to paste here, so I've pasted the back half of the log with an error. Dumps copied Main finished Adding firewall rules... Firewall rules added Replacing config files... Config files replaced Installing MySql... MySql installed Installing apache service... Apache service installed Installing CMS content... CMS content installed Creating link and icons... Icons and links created... Opening control panel... Control panel opened Creating shorcut... Shortcut created ======== End of file C:\Users\Owner\AppData\Local\Temp\themler_install.log ======== ======== Content of file C:\ProgramData\Themler\hd_data\themler_508354092\startup\_logs\cms.log ======== Tue, 30 Aug 2016 20:37:01 +0000: openTheme(joomla) Tue, 30 Aug 2016 20:37:01 +0000: install CMS Tue, 30 Aug 2016 20:37:01 +0000: deployDB(joomla, joomla_, http://127.0.0.1:12080, /themler_508354092) Tue, 30 Aug 2016 20:37:10 +0000: deployCMS(joomla) Tue, 30 Aug 2016 20:38:37 +0000: configDbConnection(joomla, joomla_67800, configuration.php) Tue, 30 Aug 2016 20:38:37 +0000: run CMS (joomla), error = 0, themeName = untitled ======== End of file C:\ProgramData\Themler\hd_data\themler_508354092\startup\_logs\cms.log ======== ERROR:Unable to find file C:\Users\Owner\AppData\Roaming\..\Local\Themler\ChromeData\chrome_debug.log I'm not sure, but the last line seems wrong - you can have ...\AppData\Roaming OR \AppData\Local, but the correct path appears to be ...AppData\Local\Themler\ChromeData. And no, there's no chrome_debug.log there. Please advise. Thank you, Pam Trader
11 Comments
Support Team posted this 31 August 2016
Please try the following suggestions:
http://answers.themler.com/articles/13879/themler-desktop-troubleshooting
Hi, Please try the following suggestions: http://answers.themler.com/articles/13879/themler-desktop-troubleshooting Sincerely, Hella
ptrader
ptrader posted this 31 August 2016
Of the items noted in the support article:
1) The Diagnostics tool and error encountered were enclosed in the original message.
2) There were no issues during install and install log indicates such (attached)
3) I do not use a proxy and the software was working fine without changes to antivirus/firewall prior to incident.
4) I do not get an ERR_EMPTY_RESPONSE on startup, probably because we never get to that point.
5) I do not get a browser cache error. Browser cache was dumped anyway and did not resolve the problem. Since I can't open Themler, I can't dump the cache from the DevTools. Renaming the ChromeData folder did not fix the problem.
6) Finally, I can't run Debug mode because it doesn't exist in the install I received.
Please note that I installed Themler on a laptop and was able to run it fine from that laptop. However, I'd prefer being able to use it on my more powerful screen.
Please advise.
Pam
Hi, Of the items noted in the support article: 1) The Diagnostics tool and error encountered were enclosed in the original message. 2) There were no issues during install and install log indicates such (attached) 3) I do not use a proxy and the software was working fine without changes to antivirus/firewall prior to incident. 4) I do not get an ERR_EMPTY_RESPONSE on startup, probably because we never get to that point. 5) I do not get a browser cache error. Browser cache was dumped anyway and did not resolve the problem. Since I can't open Themler, I can't dump the cache from the DevTools. Renaming the ChromeData folder did not fix the problem. 6) Finally, I can't run Debug mode because it doesn't exist in the install I received. Please note that I installed Themler on a laptop and was able to run it fine from that laptop. However, I'd prefer being able to use it on my more powerful screen. Please advise. Pam
Hello Pam,
6. Download latest version of Themler for Windows from themler.com, install it and try to start with Themler for Wordpress and create a theme.
Hello Pam, Please follow the steps below: 1. Backup all theme folders somewhere on your computer. 2. Uninstall Themler completely and also check the box for "Remove all CMS content". 3. Check if the following folders are still present: C:\Program Files (x86)\Themler C:\ProgramData\Themler 4. If they exist, remove them. 5. Reboot the machine after uninstalling Themler, so that all Themler services are removed for sure. 6. Download latest version of Themler for Windows from themler.com, install it and try to start with Themler for Wordpress and create a theme. Please let us know the result. Sincerely, Nettie, BillionDigital Team
ptrader
Reinstalling for the third time fixed the issue.
Thanks for letting us know. Please feel free to contact us in any other case.
BillionDgital Team
Hello, Thanks for letting us know. Please feel free to contact us in any other case. Sincerely, Nettie, BillionDgital Team
alexarafatonline
alexarafatonline posted this 11 July 2025
Hi Pam, I had a similar issue with software not starting after a crash and it took me some time to figure out file paths and missing logs. Your note about the incorrect path makes sense and could be the root cause. While troubleshooting, I was reminded of how I had to check fines by license plate (consulta multas por placa) with ANT in Ecuador—having the right access and path made all the difference in resolving issues quickly. Maybe try clearing cache or reinstalling with admin rights and double-check those folder permissions. Hope you get it fixed soon!
Hi Pam, I had a similar issue with software not starting after a crash and it took me some time to figure out file paths and missing logs. Your note about the incorrect path makes sense and could be the root cause. While troubleshooting, I was reminded of how I had to check fines by license plate ([consulta multas por placa][1]) with ANT in Ecuador—having the right access and path made all the difference in resolving issues quickly. Maybe try clearing cache or reinstalling with admin rights and double-check those folder permissions. Hope you get it fixed soon! [1]: https://antmultas.org/
biganok795
biganok795 posted this 11 July 2025
There are moments when you feel especially lonely in the hustle and bustle of a big city. During one of my trips to Dubai, I realized that I just needed a company with whom I could calmly talk and relax. Then I accidentally came across VIP escort girls Al Barsha - the girls there were not only beautiful, but also very tactful, which made the evening truly comfortable. This experience helped me feel calmer and more confident, especially in an unfamiliar environment.
There are moments when you feel especially lonely in the hustle and bustle of a big city. During one of my trips to Dubai, I realized that I just needed a company with whom I could calmly talk and relax. Then I accidentally came across [VIP escort girls Al Barsha][1] - the girls there were not only beautiful, but also very tactful, which made the evening truly comfortable. This experience helped me feel calmer and more confident, especially in an unfamiliar environment. [1]: https://sexrai.com/escorts-from/uae/dubai/al-barsha/
ialexalionline
ialexalionline posted this 13 July 2025
BeautyPlus Object Remover simplifies your editing process by quickly erasing unwanted elements from photos. It's designed to save you time while delivering perfect, polished results without any hassle or complex steps. With just a few taps, you can remove distractions like photobombers, blemishes, or clutter, enhancing your images effortlessly. The tool ensures seamless edits, maintaining natural backgrounds for professional-quality outcomes. Ideal for both beginners and pros, Try BeautyPlus Object Remover makes photo retouching faster and more efficient. Enjoy flawless photos with minimal effort, letting your creativity shine. Try it today to transform your pictures into stunning, distraction-free masterpieces!
BeautyPlus Object Remover simplifies your editing process by quickly erasing unwanted elements from photos. It's designed to save you time while delivering perfect, polished results without any hassle or complex steps. With just a few taps, you can remove distractions like photobombers, blemishes, or clutter, enhancing your images effortlessly. The tool ensures seamless edits, maintaining natural backgrounds for professional-quality outcomes. Ideal for both beginners and pros, [Try BeautyPlus][1] Object Remover makes photo retouching faster and more efficient. Enjoy flawless photos with minimal effort, letting your creativity shine. Try it today to transform your pictures into stunning, distraction-free masterpieces! [1]: https://www.beautyplus.com/object-remover
babitareddyseo
babitareddyseo posted this 13 February 2026
A Russian Escort is often admired for her confidence, beauty, and charming personality. She brings warmth and sophistication to any occasion, whether it is a dinner date or a private meeting. A Russian Escort knows how to engage in meaningful conversations while maintaining elegance and respect. Clients appreciate the balance of friendliness and professionalism. Her presence can turn an ordinary evening into a special memory filled with comfort and enjoyable company.
A Russian Escort is often admired for her confidence, beauty, and charming personality. She brings warmth and sophistication to any occasion, whether it is a dinner date or a private meeting. A [Russian Escort][1] knows how to engage in meaningful conversations while maintaining elegance and respect. Clients appreciate the balance of friendliness and professionalism. Her presence can turn an ordinary evening into a special memory filled with comfort and enjoyable company. [1]: https://hotrussian.in/
vaanibatraseo
vaanibatraseo posted this 10 June 2026
Noida Escorts are perfect for gentlemen who enjoy stylish companionship, exciting nightlife, and classy social experiences. Their charming personalities and fashionable appearance create a comfortable atmosphere for memorable evenings. From private outings to luxury parties, these companions know how to make every moment enjoyable. Book premium companionship today and experience the comfort, elegance, and positive vibes that make Noida Escorts nightlife more entertaining and special.
Noida Escorts are perfect for gentlemen who enjoy stylish companionship, exciting nightlife, and classy social experiences. Their charming personalities and fashionable appearance create a comfortable atmosphere for memorable evenings. From private outings to luxury parties, these companions know how to make every moment enjoyable. Book premium companionship today and experience the comfort, elegance, and positive vibes that make [Noida Escorts][1] nightlife more entertaining and special. [1]: https://noida.kavyamehra.com/
chanchalrani611
chanchalrani611 posted this 17 July 2026
Our agency thrives on creating moments that feel personal and thrilling. When you choose a Moti Bagh Escort, you're choosing more than just company; you're choosing an experience. We prioritize your comfort and desires, ensuring every encounter is memorable. Trust us to deliver warmth, seduction, and genuine companionship throughout your time together.
Our agency thrives on creating moments that feel personal and thrilling. When you choose a [Moti Bagh Escort][1], you're choosing more than just company; you're choosing an experience. We prioritize your comfort and desires, ensuring every encounter is memorable. Trust us to deliver warmth, seduction, and genuine companionship throughout your time together. [1]: https://www.a1delhiescort.in/moti-bagh-escorts.html
