THEMLER HTML : image transform / preview image
djskunik
djskunik posted this 31 August 2016
I use Themler HTML. I would get a zoom effect photo gallery on mouse over. I added a photo and does not work option: image - more options - effects - transform.
I would like to photograph expanding, when you move the mouse.
how to do it ?
I tried the Hover Box, but you can probably get this effect.
the question of whether you can get a regular preview image in terms of clicks so that there is a preview image. please help.
Hello, I use Themler HTML. I would get a zoom effect photo gallery on mouse over. I added a photo and does not work option: image - more options - effects - transform. I would like to photograph expanding, when you move the mouse. how to do it ? I tried the Hover Box, but you can probably get this effect. the question of whether you can get a regular preview image in terms of clicks so that there is a preview image. please help.
Support Team posted this 01 September 2016
To make the transform work you need a separate hover state with own transformation.
Unfortunately Themler does not provide the option to configure hover state for Images.
If you know css you can make such effect manually.
Hi, To make the transform work you need a separate hover state with own transformation. Unfortunately Themler does not provide the option to configure hover state for Images. If you know css you can make such effect manually. Thank you, Olivia
