Hello friends, Anyone know how to edit php and link in themler,
tikungan.bali2
tikungan.bali2 posted this 06 September 2016
examples such as this,
I want to create a template that is easy to custome, so to edit images and other content directly menggunakn widget templates zerif crate pro eg
i will modif my web. www.bisniskaraoke.com.
And how to custome and put buttom login
And how to put lisensi template ini themes ,
examples such as this, I want to create a template that is easy to custome, so to edit images and other content directly menggunakn widget templates zerif crate pro eg i will modif my web. www.bisniskaraoke.com. And how to custome and put buttom login And how to put lisensi template ini themes ,
Support Team posted this 06 September 2016
Sorry, all your explanations are not clear.
If you create the content inside Themler, then it will be able to edit it in the Themler editor only, in other case it will be presented as the shortcodes in the CMS back end.
The login module should be added from the CMS back end.
Hi, Sorry, all your explanations are not clear. If you create the content inside Themler, then it will be able to edit it in the Themler editor only, in other case it will be presented as the shortcodes in the CMS back end. The login module should be added from the CMS back end. Sincerely, Hella
tikungan.bali2
oke thanks for attention
Support Team posted this 07 September 2016
