Phoca Gallery Plugin
info1190
info1190 posted this 06 September 2016
Hi! I'm using the phoca gallery plugin to display thumbnails on several posts (joomla template). This works fine on larger screens and tablets, but not on phones. The number of columns changes automatically when I scale the browser window. On phones the entire layout is far too wide. Obviously a template issue … (or plugin)?
Example URL: http://cnc.ch10.serverline.ch/index.php/projekte/nach-materialien/aluminium
Thanks for any hint, I've been trying to solve the problem for hours so far ;-)
Hi! I'm using the phoca gallery plugin to display thumbnails on several posts (joomla template). This works fine on larger screens and tablets, but not on phones. The number of columns changes automatically when I scale the browser window. On phones the entire layout is far too wide. Obviously a template issue … (or plugin)? Example URL: http://cnc.ch10.serverline.ch/index.php/projekte/nach-materialien/aluminium Thanks for any hint, I've been trying to solve the problem for hours so far ;-)
6 Comments
Support Team posted this 07 September 2016
The issue comes from the Bootstrap file loaded by the Phoca plug-in. It has the fixed width value for all containers. If possible you can switch it off or remove so the site will use the Bootstrap file from the template. If not possible, add this code under the Home >> Settings >> Additional CSS inside Themler:
.container
width:auto!important;
Hi, The issue comes from the Bootstrap file loaded by the Phoca plug-in. It has the fixed width value for all containers. If possible you can switch it off or remove so the site will use the Bootstrap file from the template. If not possible, add this code under the Home >> Settings >> Additional CSS inside Themler: .container { width:auto!important; } Sincerely, Hella
info1190
info1190 posted this 07 September 2016
Hi Hella
I just added the code to the css and now it works perfectly on all devices! Once again fast and excellent support!
You saved my life ;-)
Thanks a lot!
Cheers, Reto
Hi Hella I just added the code to the css and now it works perfectly on all devices! Once again fast and excellent support! You saved my life ;-) Thanks a lot! Cheers, Reto
info1190
Oops, just found out, that the entire layout of the template is now fluid, but i need it boxed …
info1190
I could solve it by changing the phocagallery bootstrap.min.css by replacing .container{width:940px} with .container{width:auto}, so the template layout stays boxed.
Yes, this is the best solution, great that you have managed it.
Please feel free to contact us in any other occasion.
Hi, Yes, this is the best solution, great that you have managed it. Please feel free to contact us in any other occasion. Sincerely, Hella
pesagi6751
pesagi6751 posted this 10 June 2026
Lightweight industrial design with aluminium profiles is transforming modern construction and manufacturing industries by offering a perfect balance of strength, durability, and efficiency. Aluminium profiles are widely used because they are significantly lighter than traditional materials like https://www.xinhealuminium.com/construction-profiles/ and making them easier to transport, handle, and install without compromising structural performance. Their corrosion resistance ensures long-term reliability, even in harsh environmental conditions, reducing maintenance costs and improving lifespan. In industrial applications, these profiles support flexible and modular designs, allowing engineers to create customized structures for machinery, frameworks, and construction systems. Additionally, aluminium’s high strength-to-weight ratio enhances safety and stability while supporting sustainable building practices. With advanced extrusion technology, aluminium profiles can be shaped into complex designs, making them ideal for modern lightweight industrial solutions.
