Themes aren't working Artisteer
Web Design St.Petersburg
Web Design St.Petersburg posted this 03 August 2014
I recently purchased two themes and uploaded them to Artisteer. After I develop the content, I export the zip file to my 'add new themes' in WordPress. The problem is there is no buttons that say 'add content' or 'replaced content' in the theme panel. Therefore is is not importing the content I created in the .artx file even though I've checked off import the zip archive, include artx project and include content.
If I'm using one of Artisteer stock themes I don't have this problem. Is this a flaw in your theme templates. I addressed this issue with Artisteer, but I have not heard back from them.
Please advise
Peter Scribner
info@webdesignstpetersburgfl.com
Hi, I recently purchased two themes and uploaded them to Artisteer. After I develop the content, I export the zip file to my 'add new themes' in WordPress. The problem is there is no buttons that say 'add content' or 'replaced content' in the theme panel. Therefore is is not importing the content I created in the .artx file even though I've checked off import the zip archive, include artx project and include content. If I'm using one of Artisteer stock themes I don't have this problem. Is this a flaw in your theme templates. I addressed this issue with Artisteer, but I have not heard back from them. Please advise Thanks, Peter Scribner info@webdesignstpetersburgfl.com
Support Team posted this 04 August 2014
Could you please attach the .artx file and the exported .zip file so we could understand if the issue is somehow related to the BillionThemes.
Also what exact WP version you are using?
Hi, Could you please attach the .artx file and the exported .zip file so we could understand if the issue is somehow related to the BillionThemes. Also what exact WP version you are using?
One more hint. Make sure that you have pressed the Include content check box in the Artisteer export dialog. After that you need to upload the theme to the site, activate it and the yellow message with the Install Content button will appear.
Best regards,
Hi, One more hint. Make sure that you have pressed the Include content check box in the Artisteer export dialog. After that you need to upload the theme to the site, activate it and the yellow message with the Install Content button will appear. Best regards, BillionDigital Team
shaulhadar
shaulhadar posted this 04 August 2014
Hi Peter, in case you still are not able to find the import content button try two things:
1. disable all plugins before you upload and activate the theme and check if it works.
2. update wordpress to be 3.9.1, I have found that on older wordpress version the import content function vanishes.
I hope you succeed :)
Hi Peter, in case you still are not able to find the import content button try two things: 1. disable all plugins before you upload and activate the theme and check if it works. 2. update wordpress to be 3.9.1, I have found that on older wordpress version the import content function vanishes. I hope you succeed :)
Support Team posted this 05 August 2014
Hi Peter,
Just to follow up - such issues with missing "Import" options on WordPress are often caused by SEO plug-ins.
Try disabling a SEO plug-in, if you have one, to import content from a theme.
Best regards,
Hi Peter, Just to follow up - such issues with missing "Import" options on WordPress are often caused by SEO plug-ins. Try disabling a SEO plug-in, if you have one, to import content from a theme. Best regards, BillionDigital Team
alexarafatonline
alexarafatonline posted this 04 October 2025
Hey Peter, I had a similar issue before when working with custom Artisteer themes—it turned out to be a compatibility problem between the export settings and the newer WordPress versions. You might want to double-check the export options or re-save the .artx file. On a side note, while troubleshooting that, I came across std testing near me services that impressed me with their certified nurses, lab-verified results, and 100% confidential setup. They even offer mobile nurse visits and bilingual (English/Spanish) support, kind of like how a theme should work—simple, fast, and stress-free once everything’s configured right.
Hey Peter, I had a similar issue before when working with custom Artisteer themes—it turned out to be a compatibility problem between the export settings and the newer WordPress versions. You might want to double-check the export options or re-save the .artx file. On a side note, while troubleshooting that, I came across [std testing near me][1] services that impressed me with their certified nurses, lab-verified results, and 100% confidential setup. They even offer mobile nurse visits and bilingual (English/Spanish) support, kind of like how a theme should work—simple, fast, and stress-free once everything’s configured right. [1]: https://rapidtestmedellin.com/
jedafeb382
jedafeb382 posted this 23 October 2025
Ace the Appian Certified Associate Developer (ACD201) exam using DumpsTool’s reliable ACD201 Dumps. These updated questions cover process modeling, app design, interfaces, and Appian best practices. Gain hands-on readiness through real exam scenarios and master essential development concepts for Appian certification with trusted and verified learning resources.
Ace the Appian Certified Associate Developer (ACD201) exam using DumpsTool’s reliable [ACD201 Dumps][1]. These updated questions cover process modeling, app design, interfaces, and Appian best practices. Gain hands-on readiness through real exam scenarios and master essential development concepts for Appian certification with trusted and verified learning resources. [1]: https://www.dumpstool.com/ACD201-exam.html
s8659960
s8659960 posted this 30 December 2025
The Certsmania DOP-C02 Certification exam is designed for professionals seeking to validate their expertise in deploying, operating, and managing applications on cloud platforms. This certification focuses on assessing practical skills in configuring, monitoring, and troubleshooting cloud-based environments, ensuring candidates can handle real-world operational challenges efficiently. Topics covered include application deployment, automation, security, scaling, and performance optimization. The exam evaluates a candidate’s ability to implement best practices for cloud operations, manage resources effectively, and ensure high availability and reliability of services. Ideal for cloud engineers, DevOps professionals, and IT administrators, the DOP-C02 certification demonstrates both technical proficiency and operational excellence. Achieving this credential enhances career prospects, showcasing a candidate’s capability to manage modern cloud infrastructure with confidence and expertise in dynamic, large-scale environments.
70% Discount for Your First Exam!>>>>>>>>>>>>>> https://www.certsmania.com/amazon-web-services/pdf/dop-c02
The Certsmania DOP-C02 Certification exam is designed for professionals seeking to validate their expertise in deploying, operating, and managing applications on cloud platforms. This certification focuses on assessing practical skills in configuring, monitoring, and troubleshooting cloud-based environments, ensuring candidates can handle real-world operational challenges efficiently. Topics covered include application deployment, automation, security, scaling, and performance optimization. The exam evaluates a candidate’s ability to implement best practices for cloud operations, manage resources effectively, and ensure high availability and reliability of services. Ideal for cloud engineers, DevOps professionals, and IT administrators, the DOP-C02 certification demonstrates both technical proficiency and operational excellence. Achieving this credential enhances career prospects, showcasing a candidate’s capability to manage modern cloud infrastructure with confidence and expertise in dynamic, large-scale environments. **70% Discount for Your First Exam!>>>>>>>>>>>>>> https://www.certsmania.com/amazon-web-services/pdf/dop-c02**
