Imagen de fondo en post y blog.
Innovateg
Innovateg posted this 13 September 2016
Buenas tardes
Quisiera saber como colocar de fondo una imagen en los post y el blog en general, sin que me afecte el resto del sitio en wordpress, es decir que este fondo solo este disponible para el blog y los post.
Buenas tardes Quisiera saber como colocar de fondo una imagen en los post y el blog en general, sin que me afecte el resto del sitio en wordpress, es decir que este fondo solo este disponible para el blog y los post.
Support Team posted this 14 September 2016
You want to set the different page background for the blog template with posts? For that open that template, go to the Design >> Background and before selecting the new image, press the Customize Template styles button. Then choose the new image.
The same works with the post background. You click on the Posts control so its options appear in the top ribbon, there will be the blue option to Customize template styles. Then you can change the post background. But that background will be applied to all posts on that page.
To add the unique background for each post you will need to edit the content of each post.
Hi, You want to set the different page background for the blog template with posts? For that open that template, go to the Design >> Background and before selecting the new image, press the Customize Template styles button. Then choose the new image. The same works with the post background. You click on the Posts control so its options appear in the top ribbon, there will be the blue option to Customize template styles. Then you can change the post background. But that background will be applied to all posts on that page. To add the unique background for each post you will need to edit the content of each post. Sincerely, Hella
