Page Background & Content Background
Kaatt
Kaatt posted this 13 September 2016
I am new to Themler but experienced in Artisteer and feel like I'm missing something...
I would like to have a background on all pages set to an image and then, as it was in Artisteer, have the "content" have another style of background ontop of that. One that is inclusive of the header, article & footer in order to have a seemless transition for the background image.
I can't seem to figure out how to do this in Themler...
I am new to Themler but experienced in Artisteer and feel like I'm missing something... I would like to have a background on all pages set to an image and then, as it was in Artisteer, have the "content" have another style of background ontop of that. One that is inclusive of the header, article & footer in order to have a seemless transition for the background image. I can't seem to figure out how to do this in Themler...
16 Comments
Support Team posted this 14 September 2016
I assume that you are talking about the whole site background and the sheet background as it was in Artisteer.
In Themler you can add the page background using the Design >> Background. For the Header, Content and Footer you will need to set the background separately.
Hi, I assume that you are talking about the whole site background and the sheet background as it was in Artisteer. In Themler you can add the page background using the Design >> Background. For the Header, Content and Footer you will need to set the background separately. Sincerely, Hella
Kaatt
Kaatt posted this 14 September 2016
So the answer is "No. You can't."
That sucks....
So the answer is "No. You can't." That sucks....
No, you can not do it the same as in Artisteer. But you can use the background for several different controls as I have suggested above.
No, you can not do it the same as in Artisteer. But you can use the background for several different controls as I have suggested above. Sincerely, Hella
Kaatt
I understand that but it won't work for my design. I need a single image represented in those fields. Putting it into each won't work as the image isn't seamless
Could you please specify what you are trying to achieve? As I understand it for now, you can set Page Background and then set transparent background for other controls like Header, Content&Sidebars, Footer and containers.
Hello, Could you please specify what you are trying to achieve? As I understand it for now, you can set Page Background and then set transparent background for other controls like Header, Content&Sidebars, Footer and containers. Sincerely, Nettie, BillionDigital Team
Kaatt
I want Image A to be my background image. Behind everything in the back.
I want Image B to be situated from the header to the footer without adding it multiple times so it is one seamless photo ontop of Image A and beneath the text.
I want Image A to be my background image. Behind everything in the back. I want Image B to be situated from the header to the footer without adding it multiple times so it is one seamless photo ontop of Image A and beneath the text.
If Image B should cover Header, Content&Sidebars and Footer, then these steps should help:
1. Remove Background from Header (and Section and Container in it), Footer (and Section and Backward Links), Content&Sidebars. Set it to No Background.
2. Add Image A as background image in the Design tab.
3. Add Container to the Template. Drag Header, CMS Content and Footer into this Container so that they are at the same level (Outline in the left panel should be helpful).
4. Add Image B as background image for this Container.
Hello, If Image B should cover Header, Content&Sidebars and Footer, then these steps should help: 1. Remove Background from Header (and Section and Container in it), Footer (and Section and Backward Links), Content&Sidebars. Set it to No Background. 2. Add Image A as background image in the Design tab. 3. Add Container to the Template. Drag Header, CMS Content and Footer into this Container so that they are at the same level (Outline in the left panel should be helpful). 4. Add Image B as background image for this Container. Sincerely, Nettie, BillionDigital Team
Kaatt
I cannot seem to get it to work as you describe. The content won't drag into the new container
Could you please export and attach the theme so that we could check?
Hello, Could you please export and attach the theme so that we could check? Sincerely, Nettie, BillionDigital Team
obriensue498
obriensue498 posted this 28 October 2025
When a page background and content background are both set to an image, it creates a visually layered effect that can add depth and artistic appeal to a webpage. This approach might help in emphasizing the design theme or highlighting specific visual elements, depending on the chosen imagery and contrast. With the right balance, it could even make the layout appear more engaging and immersive.
There’s also a chance this kind of design might attract viewers who love to get info about different popular celebrities and other famous people alike portrait artist susannah blunt blending art with storytelling in a visually appealing way. It could open up creative possibilities for those exploring digital aesthetics and modern web visuals.
When a page background and content background are both set to an image, it creates a visually layered effect that can add depth and artistic appeal to a webpage. This approach might help in emphasizing the design theme or highlighting specific visual elements, depending on the chosen imagery and contrast. With the right balance, it could even make the layout appear more engaging and immersive. There’s also a chance this kind of design might attract viewers who love to get info about different popular celebrities and other famous people alike portrait artist [susannah blunt][1] blending art with storytelling in a visually appealing way. It could open up creative possibilities for those exploring digital aesthetics and modern web visuals. [1]: https://milomagazine.co.uk/
lifordwill1122
lifordwill1122 posted this 29 October 2025
That’s a great question! Setting up layered backgrounds in Themler can be a bit tricky at first, but once you get the hang of the content container settings, it becomes much easier to achieve that seamless overlay effect. I’ve had a similar challenge while designing sites for estate agents Goodmayes, and using a transparent content background over a fixed page image worked perfectly. Hope you find the right balance for your layout!
That’s a great question! Setting up layered backgrounds in Themler can be a bit tricky at first, but once you get the hang of the content container settings, it becomes much easier to achieve that seamless overlay effect. I’ve had a similar challenge while designing sites for [estate agents Goodmayes][1], and using a transparent content background over a fixed page image worked perfectly. Hope you find the right balance for your layout! [1]: https://estateagentsilford.co.uk/
mehexeg605
mehexeg605 posted this 29 October 2025
Page Background: The overall backdrop of your entire project or page. It appears behind all content (text, images, videos). You can set a color, gradient, pattern, or image here. It affects the whole canvas.
Content Background: The background of a specific element or section within the page (like a text box, card, or image container). It allows you to highlight or separate that content from the rest of the page while keeping the main page background visible. https://blackfridayy.fi/
Page Background: The overall backdrop of your entire project or page. It appears behind all content (text, images, videos). You can set a color, gradient, pattern, or image here. It affects the whole canvas. Content Background: The background of a specific element or section within the page (like a text box, card, or image container). It allows you to highlight or separate that content from the rest of the page while keeping the main page background visible. https://blackfridayy.fi/
rossangel435
rossangel435 posted this 29 October 2025
VidMate APK is a video downloader that lets users save videos and music from YouTube, Facebook, and over 1000 sites. It supports HD downloads, fast speeds, and offline viewing. VidMate also offers built-in media management and a simple interface for easy content access.
[VidMate APK][1] is a video downloader that lets users save videos and music from YouTube, Facebook, and over 1000 sites. It supports HD downloads, fast speeds, and offline viewing. VidMate also offers built-in media management and a simple interface for easy content access. [1]: https://vidmateapks.app/
rossangel435
GB WhatsApp is a popular WhatsApp mod that enhances messaging with extra features. It offers advanced privacy options, chat customization, and file-sharing upgrades. Users can send large media files, apply unique themes, and control read receipts easily for a flexible chatting experience.
[GB WhatsApp][1] is a popular WhatsApp mod that enhances messaging with extra features. It offers advanced privacy options, chat customization, and file-sharing upgrades. Users can send large media files, apply unique themes, and control read receipts easily for a flexible chatting experience. [1]: https://gbwhatsap.app/
rossangel435
Fake PhonePe APK is a simulation app designed for creating prank payment screenshots. It mimics real PhonePe interfaces for entertainment or testing purposes. Users can generate fake transaction receipts instantly, making it a fun app for jokes or demonstrations without actual money transfers.
[Fake PhonePe APK][1] is a simulation app designed for creating prank payment screenshots. It mimics real PhonePe interfaces for entertainment or testing purposes. Users can generate fake transaction receipts instantly, making it a fun app for jokes or demonstrations without actual money transfers. [1]: https://fakephonepeapk.one/
adam.smith.as123321
adam.smith.as123321 posted this 03 November 2025
That’s a great question, Themler handles backgrounds a bit differently than Artisteer, which can definitely be confusing at first. In Themler, instead of applying a single background layer site-wide, you’ll often need to use container-level styling or page wrappers to achieve that layered effect. Try setting your global background image on the “Page” or “Body” level, then apply a semi-transparent or solid background to the main “Content Wrapper” (which includes header, content, and footer). This gives the illusion of one cohesive overlay across all sections while maintaining the global image beneath.
If you’re designing for property or business websites, this layered style can look especially professional when showcasing listings or brand imagery. For example, integrating consistent visuals with efficient backend systems can really elevate presentation and usability. You can see how this concept applies to professional rental management platforms that focus on clarity, consistency, and user experience. Visit https://propertymanagementcompany.uk/
That’s a great question, Themler handles backgrounds a bit differently than Artisteer, which can definitely be confusing at first. In Themler, instead of applying a single background layer site-wide, you’ll often need to use container-level styling or page wrappers to achieve that layered effect. Try setting your global background image on the “Page” or “Body” level, then apply a semi-transparent or solid background to the main “Content Wrapper” (which includes header, content, and footer). This gives the illusion of one cohesive overlay across all sections while maintaining the global image beneath. If you’re designing for property or business websites, this layered style can look especially professional when showcasing listings or brand imagery. For example, integrating consistent visuals with efficient backend systems can really elevate presentation and usability. You can see how this concept applies to professional rental management platforms that focus on clarity, consistency, and user experience. Visit https://propertymanagementcompany.uk/
