Google fonts with IE / Edge
Kos
Kos posted this 15 September 2016
making the new website and tried to test it the look on different Browsers and it's looks like IE or Edge does not recognise the Google font on the menu. In the attachment you can see the Edge menu font does not the same as Firefox...
I have been Googling to find the similar problems and its looks like that not all the fonts are supported by IE/Edge, but there is some workarounds...
Can you please advice how to fix this inside Themler?
P.S. you can see the website name in the attchment if you need to see it by yourself
Kos
Hi, making the new website and tried to test it the look on different Browsers and it's looks like IE or Edge does not recognise the Google font on the menu. In the attachment you can see the Edge menu font does not the same as Firefox... I have been Googling to find the similar problems and its looks like that not all the fonts are supported by IE/Edge, but there is some workarounds... Can you please advice how to fix this inside Themler? P.S. you can see the website name in the attchment if you need to see it by yourself Regards, Kos
Support Team posted this 19 September 2016
I'm sorry for delay in response.
In general you can also add the fonts using the Google Fonts, the instruction can be seen here:
https://developers.google.com/fonts/docs/getting_started
The tag should be added in the Theme Settings >> Additional HTML tab and the CSS code in th Theme Settings >> Additional CSS.
Have you followed it?
There's no specific workaround for Google web fonts for IE/Edge in Themler themes. Let us know what workaround you have found and we'll help you to incorporate them into your theme.
Hello, I'm sorry for delay in response. In general you can also add the fonts using the Google Fonts, the instruction can be seen here: https://developers.google.com/fonts/docs/getting_started The tag should be added in the Theme Settings >> Additional HTML tab and the CSS code in th Theme Settings >> Additional CSS. Have you followed it? There's no specific workaround for Google web fonts for IE/Edge in Themler themes. Let us know what workaround you have found and we'll help you to incorporate them into your theme. regards, Aileen
