Empty Images
jgagne
jgagne posted this 19 September 2016
Support,
I noticed when going through the html code there are references to below:
background-image:url(0ab8656afa5c31343a20d0ad53d3caf9_dreamstime_l_49014560.jpg)
http://cstatic.billiondigital.com/themler/348/images/defaultImage.jpg"
What are these?
Joe
Support, I noticed when going through the html code there are references to below: background-image:url(0ab8656afa5c31343a20d0ad53d3caf9_dreamstime_l_49014560.jpg) http://cstatic.billiondigital.com/themler/348/images/defaultImage.jpg" What are these? Joe
Support Team posted this 19 September 2016
Please provide more details about where you have found it so we could understand what these images are.
Hi, Please provide more details about where you have found it so we could understand what these images are. Sincerely, Hella
jgagne
Hella,
I was going through the html code of the page and came across this on multiple pages.
Joe
Hella, I was going through the html code of the page and came across this on multiple pages. Joe
What HTML code? In the downloaded theme, section? In the exported theme? On the live site? It is not clear. The link is to the dummy image used when there is no image specified in some section that supposed to have an image in it.
What HTML code? In the downloaded theme, section? In the exported theme? On the live site? It is not clear. The link is to the dummy image used when there is no image specified in some section that supposed to have an image in it. Sincerely, Hella
jgagne
jgagne posted this 21 September 2016
Hella,
That is what I figured. For the dummy image can I remove the code or will it screw up things?
Joe
Hella, That is what I figured. For the dummy image can I remove the code or will it screw up things? Joe
Support Team posted this 21 September 2016
I assume that you can take it out and it'll be fine without it. But make a back up just in case something goes wrong.
Hi, I assume that you can take it out and it'll be fine without it. But make a back up just in case something goes wrong. Sincerely, Hella
