Mobile Menu not working on iphone
richard25
richard25 posted this 15 August 2017
The mobile menu is not working on the site below for iphones
http://www.backbeatbeatles.com/
It is fine for Android.
It is the '4 faces' image that is causing the problem but I have sets its z-index to 0 and the menu and its related components all to 5 and this has not fixed the problem
Cheers
Hi The mobile menu is not working on the site below for iphones http://www.backbeatbeatles.com/ It is fine for Android. It is the '4 faces' image that is causing the problem but I have sets its z-index to 0 and the menu and its related components all to 5 and this has not fixed the problem Cheers
6 Comments
Support Team posted this 15 August 2017
I do not see the z-index property specified for the menu control, set it to some high value.
Hi, I do not see the z-index property specified for the menu control, set it to some high value. Sincerely, Hella
richard25
It seems to be set as stated already.
Cheers
Hi It seems to be set as stated already. Cheers
richard25
I've solved it. I needed to set the top level menu setting to the high index as per screenshot
Cheers
Hi I've solved it. I needed to set the top level menu setting to the high index as per screenshot Cheers
Nice to hear that the issue is solved.
Hi, Nice to hear that the issue is solved. Sincerely, Hella
Abbas Khan
Abbas Khan posted this 06 October 2024
Hmm! Thanks for sharing the best information. Learn about Whos older Tristan or Andrew?
Hmm! Thanks for sharing the best information. Learn about [Whos older Tristan or Andrew][1]? [1]: https://englishlush.com/is-tristan-tate-older-than-andrew/
swanbella
swanbella posted this 28 May 2025
If your mobile menu isn't working on iPhone, it could be due to compatibility issues with Safari, JavaScript errors, or touch event handling. Consulting an experienced iPhone application development company can help diagnose and fix the issue to ensure a smooth user experience across all iOS devices.
If your mobile menu isn't working on iPhone, it could be due to compatibility issues with Safari, JavaScript errors, or touch event handling. Consulting an experienced **[iPhone application development company][1]** can help diagnose and fix the issue to ensure a smooth user experience across all iOS devices. [1]: https://www.octalsoftware.com/ios-app-development
