place headline in menu Joomla
r_ekkie
r_ekkie posted this 15 November 2015
Is it possible to place the headline in the same row as the menu but keeping the background of the menu?
www.ellouisemode.nl the headline is now above the menu and when I drag it down the whole row gets messed up.
Thank
Is it possible to place the headline in the same row as the menu but keeping the background of the menu? www.ellouisemode.nl the headline is now above the menu and when I drag it down the whole row gets messed up. Thank
Support Team posted this 16 November 2015
Try to drag it into one line with the menu. The row should be separated into two columns then. Add the black background to the whole row. If that does not help, please attach your theme to the ticket.
Hi, Try to drag it into one line with the menu. The row should be separated into two columns then. Add the black background to the whole row. If that does not help, please attach your theme to the ticket. Sincerely, Hella
