how can i replace the horizontal menu with vertical menu
george36
george36 posted this 05 May 2016
hi
the default template uses a horizontal menu... i cannot figure out how to replace this with a vertical menu..
i added a plugin into the backend but it doesnt display the menu anywhere ... the plugin uses js i think...
hi the default template uses a horizontal menu... i cannot figure out how to replace this with a vertical menu.. i added a plugin into the backend but it doesnt display the menu anywhere ... the plugin uses js i think...
10 Comments
Support Team posted this 06 May 2016
I do not understand you completely. You want to use the vertical menu designed in Themler instead of your horizontal menu? Please attach a screen shot of what you are trying to achieve.
Hi, I do not understand you completely. You want to use the vertical menu designed in Themler instead of your horizontal menu? Please attach a screen shot of what you are trying to achieve. Sincerely, Hella
george36
george36 posted this 06 May 2016
hella
the decault new theme is a horizontal menu... you mention the themler vertical menu... where is that?
see attached
george
hella the decault new theme is a horizontal menu... you mention the themler vertical menu... where is that? see attached george
You can find the example of the vertical menu under the Styles tab. Also I see that you are using the old Themler version, you can update to use more options.
Also it is still not clear from your screen shot what you are trying to achieve.
Here is the information about the vertical menu for WP:
http://answers.themler.com/articles/3626/how-to-use-wordpress-theme#menu
Hi, You can find the example of the vertical menu under the Styles tab. Also I see that you are using the old Themler version, you can update to use more options. Also it is still not clear from your screen shot what you are trying to achieve. Here is the information about the vertical menu for WP: http://answers.themler.com/articles/3626/how-to-use-wordpress-theme#menu Sincerely, Hella
george36
hella
i still dont get it... all i want is to create a simple vertical menu
your styles tb shows attributes you can change on vertical menus and your link gives an outline of how to add a vertical menu widget to the primary widget area... all you can do here is change a title... but how do you then add menu options..and pages... this menu appears nowhere in the backend
i created this then switched back to themler... i cannot find THEME > THEMLER OR APPEARANCE > THEMES to customize anywhere ... see screenshot
hella i still dont get it... all i want is to create a simple vertical menu your styles tb shows attributes you can change on vertical menus and your link gives an outline of how to add a vertical menu widget to the primary widget area... all you can do here is change a title... but how do you then add menu options..and pages... this menu appears nowhere in the backend i created this then switched back to themler... i cannot find THEME > THEMLER OR APPEARANCE > THEMES to customize anywhere ... see screenshot
george36
i think my confusion is what do you do once you have added a vertical menu to the primary widget area...
how do i add menu items to this?
then switch to themler ...
do you then go to styles tab and assign vertical menu... how do you do that exactly?
then go to back end wp... appearance>theme ...
if i click on customize on the active menu it switches to themler...
i simply dont get it... can you give me a step by step instruction please
Hella i think my confusion is what do you do once you have added a vertical menu to the primary widget area... how do i add menu items to this? then switch to themler ... do you then go to styles tab and assign vertical menu... how do you do that exactly? then go to back end wp... appearance>theme ... if i click on customize on the active menu it switches to themler... i simply dont get it... can you give me a step by step instruction please
Support Team posted this 09 May 2016
Themler theme provides Vertical Menu widget for WP (WP Appearance >> Widgets). This widget creates a menu that uses Themler Vertical Menu style (Styles tab).
As you can see this widget uses different sources including custom menu (WP Appearance >> Menus).
All you need is:
  1. Stylize vmenu under the Styles tab
  2. Enable sidebar with widget area or add WP widget area control to any place on the template
  3. Put vmenu widget into this area in WP Appearance >> Widgets.
That's all.
Hi, Themler theme provides Vertical Menu widget for WP (WP Appearance >> Widgets). This widget creates a menu that uses Themler Vertical Menu style (Styles tab). !wp-vmenu.png! As you can see this widget uses different sources including custom menu (WP Appearance >> Menus). All you need is: 1. Stylize vmenu under the Styles tab 2. Enable sidebar with widget area or add *WP widget area* control to any place on the template 3. Put vmenu widget into this area in WP Appearance >> Widgets. That's all. Please let us know if you have any further questions. Thank you, Olivia
george36
george36 posted this 09 May 2016
olivia .. i understand but i NEED a step by step example... take two pages blog and about... where exectly do you start .. backend .. yes i can ceeate a custom menu and put a widget on the default widget area... now in simple steps i select themler from wp WHAT EXACTLY DO I PRESS AND WHERE PLEASE...
Support Team posted this 11 May 2016
Ok.
We have: WordPress, two WP Pages. You want to show the links to these pages on the front end as Vertical Menu. And you have default Themler theme.
What you need? You need widget and you need a place where this widget will be outputted - a widget area. Themler provides Vertical Menu widget.
Next question is "where you want the vertical menu to appear?".
Let's consider the most common situation - you want to have a column (Sidebar) to the left/right of the Content area on all pages.
  1. go to Themler
  2. since we need a column (Sidebar) on all pages we need Themler Sidebars - shared areas used to share content between templates.
    So, enable Left Sidebar:
    As you can see, by default, Left Sidebar includes Primary Widget area control.
    Right Sidebar includes Secondary Widget area control.
  3. On this stage all you need is already done. Save changes and go to WP admin panel >> Appearance >> Widgets and put Vertical Menu widget into the Primary Widget area.
  4. Go back to Themler and refresh content:
You will see Vertical Menu in Themler.
That's all.
Hi, Ok. We have: WordPress, two WP Pages. You want to show the links to these pages on the front end as Vertical Menu. And you have default Themler theme. What you need? You need widget and you need a place where this widget will be outputted - a widget area. Themler provides Vertical Menu widget. Next question is "where you want the vertical menu to appear?". Let's consider the most common situation - you want to have a column (Sidebar) to the left/right of the Content area on all pages. 1. go to Themler 2. since we need a column (Sidebar) on all pages we need Themler Sidebars - shared areas used to share content between templates. So, enable Left Sidebar: !enable-left-sidebar.png! As you can see, by default, Left Sidebar includes **Primary Widget area** control. Right Sidebar includes **Secondary Widget area** control. 3. On this stage all you need is already done. Save changes and go to WP admin panel >> Appearance >> Widgets and put Vertical Menu widget into the Primary Widget area. 4. Go back to Themler and refresh content: !refresh-content-2.png! You will see Vertical Menu in Themler. That's all. Please keep us posted about the progress. Thank you, Olivia
george36
george36 posted this 11 May 2016
Olivia... perfect ... THANK YOU VERY MUCH...
Support Team posted this 12 May 2016
