Is there any Option, that themler will NEVER touch the Content? My Problems are:
- It removes all my paragraphs, not only if i use the build-in columns shortcode
I have installed a plugin for column shortcodes, Using this will also remove the paragraphs inside the column tags. - Wordpress YouTube Video does not work - i Need to use your shortcode for embedding Video - but the HTML Code, which is genereted by this shortcode ist soooo huge and ugly...
- It makes styles tags, inside the content, very ugly, bloated code.
Bettina
Is there any Option, that themler will NEVER touch the Content? My Problems are: - It removes all my paragraphs, not only if i use the build-in columns shortcode I have installed a plugin for column shortcodes, Using this will also remove the paragraphs inside the column tags. - Wordpress YouTube Video does not work - i Need to use your shortcode for embedding Video - but the HTML Code, which is genereted by this shortcode ist soooo huge and ugly... - It makes styles tags, inside the content, very ugly, bloated code. Regards, Bettina
